Slightly rough idle ... Normal?
Old Oct 13, 2005 | 07:46 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default Slightly rough idle ... Normal?
I'm not even 100% I have a problem, but when my car is idling, it's a little rough. It's not bad by any means, and I have always seemed to have had it since I bought it (with 17K miles). The only reason I brought it up is the other day when scanning at cold idle (open loop) the car is pretty darn smooth. The moment it goes into closed loop it gets rough. The O2 sensors look to be both working, the plugs and plug wires are new, I use good gas, etc.
I really am just looking for a "this is normal" reply. I really want to make sure everything is 100% before I get my headers and LS6 intake put on.
Thoughts?
Old Oct 13, 2005 | 11:00 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Yes, the LSx series engines all seem to have a bit of shake to them at idle; not smooth as glass like your Dad's old iron block V8, that's for sure.
Old Oct 13, 2005 | 11:04 PM
JTS97Z28's Avatar
JTS97Z28
Try this if you can reach the 02 plugs. Totally disconnect your front 02 sensors and drive around for a bit. When I had my old 97 Z28 I noticed the car run MUCH smoother in open loop all the time and like you said as soon as closed loop kicked on and it read from the 02's the idle became more rough. You will get a engine light on but that doesnt matter.
Old Oct 13, 2005 | 11:16 PM
Groucho's Avatar
Groucho
Default Same here...
Hoping to hear...
"They all do that"
Old Oct 13, 2005 | 11:38 PM
vette2k1's Avatar
vette2k1
It's normal. "They all do that."
Old Oct 13, 2005 | 11:48 PM
Groucho's Avatar
Groucho
Old Oct 13, 2005 | 11:50 PM
dragon84's Avatar
dragon84
Thank God, I was starting to wonder lol.
Old Oct 14, 2005 | 09:28 AM
JR_VETTE's Avatar
JR_VETTE
Cool! Thanks guys!
Old Oct 14, 2005 | 11:08 AM
WKMCD's Avatar
WKMCD
Mine just started shaking at idle last Sunday. That's the day I picked it up after the H/C. 230/236 112 lsa. I love it!!
Old Oct 14, 2005 | 11:16 AM
c131frdave's Avatar
c131frdave
I noticed that too! Woo Hoo!!
As a former hot rod drag racer and builder, I can tell you that it is what used to be known as "lope". It comes from the cam lobes having a wide overlap. The more overlap, the worse it is. Also, the worse it is, usually the more powerful the car is. This allows for more efficient VE at high RPMs. The LS1 was designed to make it's power upstairs, so a lopey cam makes sense.
I love it!
To Slightly rough idle ... Normal?
