throttle body install
Old Oct 14, 2005 | 07:42 PM
xxsvtcobrakidxx's Avatar
xxsvtcobrakidxx
Default throttle body install
just purchased a used shaner and looking to install it tomorrow. anything i should look for??it has the black cylinder thing attached too it should i swap mine on to there?? not even sure what its called. i also noticed that the blade is slightly open now. is this normal or will it change once i install it and hook up all the connectors thanks guys
Old Oct 15, 2005 | 07:03 PM
vettenuts's Avatar
vettenuts
Open blade is normal. If you depress it then it will spring back. If the throttle position sensor is intalled on the passenger side and the throttle motor on the driver's side, you will need a new throttle body gasket, a torque wrench and some other basic tools to do the change. Throttle body bolt torque value is 106 lb-in. Careful how you handle it, don't bang it around. Best to do with motor cold so you don't lose any coolant.
Old Oct 16, 2005 | 12:26 AM
Dr Chill's Avatar
Dr Chill
Get a bypass kit from Home Depot and install that at the same time. This will make any TB work much easier. And I hear it's also good for about 75 hp too
Old Oct 16, 2005 | 12:32 AM
dragon84's Avatar
dragon84
75 hp???
To throttle body install
