342 rear end question???????????????
Old Oct 15, 2005 | 09:50 PM
glind46677's Avatar
glind46677
Default 342 rear end question???????????????
I just put a 342 gear in my 2004 auomatic. At 60mph my rpm are 2200 and at 70 they are 2500. Does that seem high or about right???
Old Oct 15, 2005 | 09:56 PM
Chuck01's Avatar
Chuck01
Default 3.42
That sounds about right might be just a tad high.
I bet you think the first time you drove it you thought it was a different car?
Old Oct 15, 2005 | 11:40 PM
Mitch C's Avatar
Mitch C
If you have 3.42 gears you should be at 2150 RPM locked up in 4th gear at 70 MPH. You should not be at 2500 RPM at 70 MPH if your car is shifting into 4th gear and locking up. It sounds to me like your car might not be locking up in 4th assuming you really have 3.42s. FWIW my car has 3.73s and I am at only 2350 RPM at 70 MPH locked up in 4th gear.
Old Oct 16, 2005 | 12:37 AM
dragon84's Avatar
dragon84
ttt for ya
Old Oct 16, 2005 | 09:01 AM
BIGMAC's Avatar
BIGMAC
With Mitch C. 2150 RPM with 3.42 gears at 70 mph.
Old Oct 16, 2005 | 10:17 AM
Mike Mercury's Avatar
Mike Mercury
in 3rd gear - doing 75mph, you should see 3400 rpm with the A4. This will verify that you indeed have a 3.42 rear ratio.
who did your reprogram ?
Old Oct 16, 2005 | 05:00 PM
glind46677's Avatar
glind46677
Kevin Polchin did the reprogram on the gears.
Old Oct 17, 2005 | 12:13 AM
Chuck01's Avatar
Chuck01
Just doubled check and that is high. At 75 you should be at 2250 rpm.
Old Oct 17, 2005 | 12:29 PM
grinder11's Avatar
grinder11
Maybe he's got small (real) tires. Seriously, has anyone questioned the tire sizes? Also, is it true that the 6 speeds need no re-cal on the speedo? I have heard that the A4 cars do, but not the 6 speeds. Please advise, though a little off topic. Sorry.
Old Oct 17, 2005 | 01:03 PM
Mike Mercury
neither do. There is no speedo error on the C5 caused by rear axle ratio changes - A4 or manual shift.
read here:
http://mikemercury.home.att.net/342.htm
Old Oct 17, 2005 | 04:44 PM
maacoman's Avatar
maacoman
3.42"s with Yank SS 3600,70MPH=about 2200RPM in lockup
John
Old Oct 17, 2005 | 11:04 PM
99 vett babycar's Avatar
99 vett babycar
ss3600 3.42 2100 RPM @ 70MPH TONIGHT.
Old Oct 18, 2005 | 12:14 PM
Mike04's Avatar
Mike04
My 3.42 do 98mph at 3000rpm (if you want to try another speed)
Old Oct 18, 2005 | 05:33 PM
6 Kids's Avatar
6 Kids
St. Jude Donor '06
Guys! I know this is an important topic but did you see Maacoman's avatar? Alright dude!
Old Oct 20, 2005 | 04:21 PM
maacoman's Avatar
maacoman
Thanks Steve, got it from Viper Alley pics section.
John
Old Oct 21, 2005 | 08:16 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
With stock tires (26.7" Dia.) in D (4th gear) at 70 mph, a 3.42 gear C5 will produce approx. 2100 rpm's...If your reading are much higher than that, the tires are not 26.7" Dia., you don't have a 3.42 gear or your tach is wrong....Good luck in sorting it out.
To 342 rear end question???????????????
