Engine hot after I rinsed off engine??
Old Oct 20, 2005 | 10:34 PM
Dylan 93Z's Avatar
Dylan 93Z
Default Engine hot after I rinsed off engine??
I rinsed off my engine today and after doing so I drove the car around and noticed now it likes to get to 240 degrees and stay there.. I checked for any items stuck in the radiator area and even rinsed it down to make sure there wasnt any dirt. Still gets hot even in the driveway. Any ideas?
Old Oct 21, 2005 | 12:58 AM
skeet's Avatar
skeet
Putting cold water on a hot engine can warp many parts. Wondering if your warped the heads and now have a head gasket problem? Hope not.
Old Oct 21, 2005 | 01:59 AM
NSTG8R's Avatar
NSTG8R
check to make sure nothing is blocking the radiator
Old Oct 21, 2005 | 05:24 AM
Dylan 93Z's Avatar
Dylan 93Z
Engine was cool for the most part when I did this. I also got out the air hose and blew off the A/C condensor and radiator and still in the driveway at idle the car does not like to go below 239 degrees with the the fans on. I am going to change the t-stat next...
Old Oct 21, 2005 | 06:56 AM
VetteMed's Avatar
VetteMed
Does the car get hot on the highway? (60mph sustained)
-A.
Old Oct 21, 2005 | 07:01 AM
Dylan 93Z's Avatar
Dylan 93Z
it will decrease at highway speed, i did notice that the hose going to the t-stat side is MUCH cooler and actually not hot at all while the car is hot.
Old Oct 21, 2005 | 09:28 AM
Dylan 93Z's Avatar
Dylan 93Z
update: looks like it was a bad t-stat afterall. as soon as i touched the t-stat hose and it wasnt hot i pretty much knew that was were i needed to focus.... it works and cools nicely now! thanks for the replies guys!!
To Engine hot after I rinsed off engine??
