Brake pad questions
Old Oct 16, 2005 | 02:31 PM
POLOVETTE 94's Avatar
POLOVETTE 94
Co-winner 2020 C4 of the Year - Modified
Default Brake pad questions
Hello from the C4 section. I have a 94, with the C5 front brake conversion. What pads do you recommend? I would like good stopping power, but would prefer low dust and very little noise. I tried the ceramic pads, but feel they don't have the initial bite I'd like. They are quiet and low dust, but they feel a bit mushy. Please share your brake pad experiences. Thanks.
Old Oct 16, 2005 | 03:32 PM
rws.1's Avatar
rws.1
Go for the stock Z06 brake pads then.... Gene at Fred Beans will give you a good price... see his October C5 specials post a couple days ago in the C5 general ( or parts) section
Old Oct 16, 2005 | 04:53 PM
POLOVETTE 94
Are the Z06 pads different from the LS1 C5 pads? Also, I did my conversion back in 2000, so my C5 calipers are from somewhere in the 97-00 range. Are all years of C5 brake pads the same, or did they change at some time? Thanks again.
Old Oct 16, 2005 | 05:11 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Z06 /C5 Brake Pads
The Z06 pads will fit you C5 caliper/rotors.
All C5/Z06 pads/calipers/rotors are interchangeable. As a mater of fact, the only difference between C5 & Z06 calipers is the color.
I have Z06 pads on my 2000 FRC. They are a little dirty, but they stop very well.
Bob K.
Old Oct 16, 2005 | 06:11 PM
Face's Avatar
Face
I've been using KVR. They stop great, virtually no fade, and aren't as dirty as stock.
Old Oct 16, 2005 | 09:50 PM
JGVette's Avatar
JGVette
Hawk makes a nice product. High performance, low dust
Old Oct 24, 2005 | 10:36 PM
POLOVETTE 94
Any other suggestions on pads? How about new rotors?
Old Oct 25, 2005 | 12:16 PM
Sean2000C5's Avatar
Sean2000C5
I use stock rotors they last long and work fine. I track my car a few times a year and have no problems with warping or excess wear. Napa has the same rotor available minus the painted hat for about 25-30 bucks. I did switch from stock Z06 pads to EBC Red pads which have a higher heat tolerance and better bite when hot. I'm due for pads and rotors soon so I'll be using stock rotors and I'm still thinking about pads. The EBCs give up a little cold stopping power for the benefits when hot.
To Brake pad questions
