Do I need new Valve Springs....
Old Oct 17, 2005 | 03:45 PM
MikeTennent's Avatar
MikeTennent
Default Do I need new Valve Springs....
I am installing a set of Crane Roller Rockers. Do I need new valve springs? My engine has only 21000 miles on it.....2000 'Vette.
Old Oct 17, 2005 | 04:19 PM
maacoman's Avatar
maacoman
Need more Info,are you still running the stock cam?
John
Old Oct 17, 2005 | 05:09 PM
lost's Avatar
lost
If you are going to a higher ratio rocker, like a 1.8, you will need upgraded valve springs. If you have future plans that include a cam, might as well do the springs.
Old Oct 18, 2005 | 08:32 PM
MikeTennent
Default Mostly stock at this time...
Other than Supermaxx headers, Nology wires, Miziere water pump and vararam intake, the engine is stock. I do plan on heads in the future. Guess I should go ahead and do the springs. Any suggestions on what springs to install?
Old Oct 18, 2005 | 08:45 PM
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
In your case Comp 918's would be the best choice.
Old Oct 18, 2005 | 09:41 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
To Do I need new Valve Springs....
