Problems with my trunk release...
Old Oct 17, 2005 | 08:41 PM
Lithium's Avatar
Lithium
Default Problems with my trunk release...
Anyone else had a problem with the the trunk/hatch not opening when you press the button on the fob or the switch inside the car? It eventually works if you turn on and off the car a couple times and drive around. It's pretty wierd. Anyway, anyone know how I might go about fixing this dilema???
--Marc
Old Oct 17, 2005 | 08:47 PM
B Taylor's Avatar
B Taylor
St. Jude Donor '08
Only problem I had was when my battery went dead. Couldn't open the truck (electric). There is a manual wire in the middle truck compartment of the vert, but there isn't a chance you can get to it (particularly with my hoops). Good luck, sounds electrical, may want to check the connections at the button and ground.
Old Oct 17, 2005 | 08:51 PM
rws.1's Avatar
rws.1
Whenever I have had problems with fob remotes, the first thing I have doen is change the battery. Often a weak battery will let one function work but others won't. Since batteries are cheap, It is always a good place to start.
Old Oct 17, 2005 | 08:54 PM
Lithium's Avatar
Lithium
Even if all the other buttons work fine??
--Marc
To Problems with my trunk release...
