spring replacement
Old Oct 18, 2005 | 08:54 AM
dusterbd13's Avatar
dusterbd13
Default spring replacement
the 97 coupe that ive been doing a lot of work on needs stiffer springs. i was wondering how hard these are for youre average competent mechanic to replace. the rear doesnt look too difficult, and i havent looked at the front yet. any suggestions? tips on how to do this?
thanks, y'all.
michael
Old Oct 18, 2005 | 11:13 AM
CrazyChris's Avatar
CrazyChris
Here is a writeup for a F-Body, but it is the same for the C5. http://www.ls1howto.com/index.php?article=23
It isn't hard with the right tools...
Old Oct 18, 2005 | 11:20 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I think he was talking suspension, not valvesprings.
Old Oct 18, 2005 | 01:52 PM
dusterbd13's Avatar
dusterbd13
yessir, i was talking about the fiberglass transverse suspension springs. thanks for the valvespring info, though.
michael
Old Oct 18, 2005 | 02:44 PM
M_T_0's Avatar
M_T_0
front is tuffer than back but doable, you have to drop the lower a-arms to get the old spring out and be sure to get it centered before re-attaching the lower a-arms.
look at the ls1howto site.
More Than Zero
Old Oct 18, 2005 | 05:55 PM
VetteSiNz's Avatar
VetteSiNz
I use this one: http://www.ls1howto.com/index.php?article=20
When you remove the upper A arm bolt, take a note about the washer behind the A arm.
Old Oct 18, 2005 | 10:40 PM
Rex99Coupe's Avatar
Rex99Coupe
Very easy if you follow instructions on LS1howto.com. I bought a tap to clean up the threads for the upper control arm bolts, since they were installed with locktite. Just put the washers back in same location, otherwise you could mess up the alignment. Had to smack the front spring with a block of wood to get it out, not difficult though.
Old Oct 19, 2005 | 09:05 AM
IM QUIKR's Avatar
IM QUIKR
I just did this one. It was getting frustrating trying to keep the rubber supports to stay in the brackets on the front spring while I was tightening the bolts. The trick was to start the bolts on both side to keep it up in the air and secure one side by running the bolts in 90-95% of the way and then using the jack on the opposite end of the spring, raise it enough to flatten the curve in the spring and then the rubber will line up nicely. Once it's torqued down the jack can be removed.
The rear was very easy to install. Just make sure you use loctite.
To spring replacement
