How would you calc HP?...
Old Oct 18, 2005 | 02:47 PM
1999 Vette's Avatar
1999 Vette
Default How would you calc HP?...
Mods on 99 A4....3.90s,3200 TC, grizzly LTHrs, K&N CAI, z06 TIT Exhaust
On Dyno Jet it ran 317 RWHP & 340TQ
Now, in a way, this is misleading! (to me at least) Because I know the 3.90s make it a faster car, but shows lower #s on the Dyno Jet. Without the 3.90s I'd be at about 330 RWHP.
SO, using the 15% drivetrain loss....if I am at 317 RWHP, then my FWHP is 373. OR can I adjust for the the "gear loss" and use the 330RWHP to get a FWHP of 388?
Now, if that gets resolved, my next question is does the 3.90s = 50RWHP gain? (Thats what I read here).
My ultimate goal is to figure, with my mods, what equivalent FWHP I have
Is it 317RWHP + 50HP from gears adding DT loss of 15%=432FWHP?
or
Is it 330RWHP + 50HP from gears adding DT loss of 15% =447FWHP?
Help!?
Old Oct 19, 2005 | 10:56 AM
1999 Vette's Avatar
1999 Vette
anyone?
Old Oct 19, 2005 | 12:15 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Because of the way the math works on a DynoJet / inertia-type dyno, yes, a car w/ something other than a 3.42 (or whatever your "stock" gear ratio's are for cars you are comparing to), w/ a higher numerical ratio will dyno slightly lower than one w/ a lower ratio.
And it doesn't have anything to do (o.k., almost nothing) w/ "friction losses" due to the smaller ring gears.
It has to do w/ the way dyno's measure torque, looking at X-amount of work being done over X-amount of time..
The consensus seems to be that 3.90's / 4.10's "loose" about 3% of the actual RWHP dyno recorded value. That's for M6 cars.. A4's are a different animal, and I have no idea. (to clarify, I've seen some really "strange" looking dyno graphs from A4 cars, esp. with aftermarket tq. converters.)
Old Oct 19, 2005 | 12:25 PM
David426's Avatar
David426
actually 15% for manual trans and 18% for automatics. Since you have 317rwhp and an automatic you must actually divide by .82 which will put your .18 powertrain loss back to the flywheel. So 317 / .82 =386.5 flywheel hp. This is what you have at the flywheel. As far as adding 50hp for lower gearing. don't know where you got that info, it does make a little difference, not that much maybe 5 hp or 10 at most.
A bone stock LS1 A4 has 287rwhp 287 divided by .82 = 350fwhp. A Mn6 will dyno around 297rwhp stock divided by .85 = 350fwhp
To get rwhp numbers from flywheel numbers for a4 tranny is
350fwhp x .18 = 63 so 350-63 gives you 287rwhp for stock A4
350fwhp x .15 = 53 so 350-53 gives you 297rwhp for stock mn6
Old Oct 19, 2005 | 12:33 PM
Dan_the_C5_Man
To clarify, I only addressed the 3.90 ~ 4.10 additional "loss" question, not the percentage lost in the driveline (approx. 15%).
Old Oct 19, 2005 | 12:56 PM
1999 Vette's Avatar
1999 Vette
Dan: thats 3% loss for the 3.90s sounds right.
I got the 50HP gain from posts on this forum. I know the gears don't actually give more HP...but do make the car faster.
I'm trying to figure out how I can compare my car (w/o going to the track). For example, if my car has 317RWHP and another identical car also has 317RWHP but with 2.73 gears, my car should be faster. Or if another car has 330RWHP and 2.73 gears, my car again should be just as fast, if not faster with the 3.90s.
My tuner said I should have 325-330RWHP with my mods, but the read of 317 was due to the gears. On paper my car may look slower than it actually is. I'm trying to create an "equivalence" factor.
Old Oct 19, 2005 | 02:30 PM
Gordy M's Avatar
Gordy M
"Mods on 99 A4....3.90s,3200 TC, grizzly LTHrs, K&N CAI, z06 TIT Exhaust"
The only way to find REAL hp/tq is on an engine dyno, the chassis dyno will show what it made that day, based on the skill of the operator. Since GM made 345 hp you can add in another 14-18 hp for the headers. That should bring you up to about 360hp. The gears, CAI, TC will add to the efficiency of the engine and in a real world situation make the car faster, over a given time span. When looking at chassis dyno sheets make sure the graph shows the hp/tq crossing at 5250 prm...you would be suprised at how much hp you can make when they cross at lower levels....
Old Oct 20, 2005 | 10:45 AM
shurite44's Avatar
shurite44
I have a different approach. Take it to the track is see how much faster it is.
If you want to know HP then take your trap speed and weight and calculate a HP.
Your qtr mile ET and trap speeds (WX corrected) will remain much more consistent than any dyno runs. No matter how you do it dyno or trap speed/weight it is just an estimate anyway.
Off course this could be impractical if you do not drag race.
Old Oct 20, 2005 | 11:08 AM
kromberg's Avatar
kromberg
You can calculate you actual rwhp at any moment in time by:
rwhp = vehicle mass * vehicle velocity * vechicle acceleration
where
vehicle mass is in kilograms
vehicle velocity is in meters/sec
vehicle acceleration is in meters/sec^2
Keith
Old Oct 20, 2005 | 11:28 AM
shurite44's Avatar
shurite44
where
Keith
Keith give me a practical example of how you do this.
Old Oct 20, 2005 | 11:34 AM
kromberg's Avatar
kromberg
First you would need to know the weight of your vehicle. Next you need to log the vehicle spped through some type of scanner. All the scanners I know of associates a time to the parameter that is being logged. You will need to convert the speed value into meters/sec from miles/hour. You can use the current logged value of speed along with the previous value to determine acceleration. Acceleration is the delta of velocity divided by delta of time.
Keith
Old Oct 20, 2005 | 03:22 PM
doubledeuce's Avatar
doubledeuce
I have a 3000 yank stall converter on my 98. Would a high stall converter decrease your powertrain loss?
Old Oct 20, 2005 | 03:44 PM
kromberg's Avatar
kromberg
Before it fully engages, yes. Afterward, no
Keith
Old Oct 20, 2005 | 03:51 PM
1999 Vette's Avatar
1999 Vette
No hijacking
Thanks for the replies. I'm still at a loss for an answer. I'll put it another way...withy my mods, how close of a race is it to say an A4 C6 (stock) which is at 400FWHP.
If you say even race, I would interpret that as my car runs like a 400FWHP car
Old Oct 20, 2005 | 03:53 PM
doubledeuce
a 3.90 gear ratio many feel fast, compared to my 3.15 gear ratio, but what's the difference in a quarter mile?
Old Oct 20, 2005 | 04:01 PM
doubledeuce
Originally Posted by 1999 Vette
No hijacking
Your car should be able to beat a A4 C6 in a 1/4 mile, it has 2.73 to 3.15 gear ratio, and a stock converter. Even if it has more hp, your drivetrain mods should push you over the 1/4 mile before that car. I recently raced a C6 and killed it
Old Oct 20, 2005 | 04:03 PM
shurite44's Avatar
shurite44
No hijacking
Other similar modded C5's with your mods run around 12 flat, I think most C6's are running mid 12's to 13. You would normally beat a C6 all things being equal I would say, a well driven Z06 would still take you in my opinion at 405 crank HP.
Does that help, just guesstimates anyway.
Old Oct 20, 2005 | 04:06 PM
1999 Vette's Avatar
1999 Vette
Guys, that does help! Thanks much!
Old Oct 20, 2005 | 04:18 PM
boatboatboat's Avatar
boatboatboat
I have an a4 with 3:73's and a 2800 TQ, and was told by my tuner to allow for a TOTAL of 22% drive train loss.
To How would you calc HP?...
