Gear And Diff Oil?
Old Oct 19, 2005 | 04:14 PM
adamcini's Avatar
adamcini
Default Gear And Diff Oil?
Hey guys, I have a 2002 C5 Auto 4-Speed, what is the exact amount of Gear Oil and the exact amount of Differential Oil I should use. Also what types do you recommend?
Adam
Old Oct 19, 2005 | 05:57 PM
vettenuts's Avatar
vettenuts
The rear differential holds about 1.7 quarts. If you use GM, you put in additive. If you use other aftermarket products, a lot have the additive in it and more is not typically required. I use Amsoil and have had good success with it right out of the bottle, no further additive required.
Old Oct 19, 2005 | 07:45 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 meets the GM requirements for the differential and is what I use on the track. As mentioned, diff takes just under two quarts. A hand pump like this comes in handy for changing diff and/or tranny fluid: AMSOIL Hand Pump
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Oct 19, 2005 | 07:51 PM
aquaholic's Avatar
aquaholic
anyone know the difference between 75w90 Red Line Heavy ShockProof Gear Oil and 75w90 Red Line Synthetic Gear Oil?? both say they are synthetic so whats the other differences?
Old Oct 30, 2005 | 03:12 PM
Var's Avatar
Var
shockproof has a special additive that makes the oil better(more stable), but is recommended for racing use only. There have been oil analysis done on shockproof and the additive can wear out as early as 500 miles. I guess it would just turn into normal redline synthetic afterwards ..?
Old Oct 30, 2005 | 04:47 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I used the redline full syn, don't use gm additive with the redline..........
To Gear And Diff Oil?
