Bilstein Install Question
Old Oct 19, 2005 | 06:09 PM
VetteGuy1999's Avatar
VetteGuy1999
Default Bilstein Install Question
Hey Guys,
The Bilstein Sports arrived today, I took one out of the box and noticed 2 rubber bushings (3/4: thick each) and a metal washer on the shaft, i the box were 2 more rubber (looks like Polyurethane) larger than the first 2 described. No instructions were in any of the boxes.
Question: why are the first 2 bushings and the washer on the shaft? Do I have a choice of which bushings to use? please help ready to install.
Also what are the torque ft/lb for the mounting bolts?
Thanks in advance for the help.
Jim
Old Oct 19, 2005 | 06:48 PM
YellowFlash's Avatar
YellowFlash
CI 7 & 9 Veteran
Old Oct 19, 2005 | 07:58 PM
VetteSiNz's Avatar
VetteSiNz
Here's an instruction I use to replace my shocks with Bilstien Sports. http://www.c5forum.com/diy/shocks.php Hope this helps.
Old Oct 20, 2005 | 09:10 AM
IM QUIKR's Avatar
IM QUIKR
The lower mounting bolts are 21 ft lbs. The upper is 19 ft lbs.
If you use the rubber bushings like I did, tighten the nut until the rubber bushing is compressed to match the diameter of the washer. The rubber bushing will be quieter and less jolting.
The order of parts on the shock assembly from bottom to top: small clip, dust shield, large washer, rubber bushing,mounting bracket, bushing, large washer and nut.
They will be somewhat shorter than stock shocks. It's easier to compress the shock on the floor and tie it down, then secure the lower mounting bolts first, then release the retainer and guide the piston up into the upper bracket as it rises, then use a floor jack to raise it up into position.
Old Oct 20, 2005 | 10:58 AM
xlr8shn's Avatar
xlr8shn
That's what I did. Parachute cord and floor jack made shock install easier!
Old Dec 23, 2005 | 07:50 PM
sambarnett's Avatar
sambarnett
When doing the rears do you transfer just the plate or the plate and the stock upper rubber bushing? I'm having trouble figuring out how to get the bushing out of the plate.
Sam
Old Dec 23, 2005 | 11:44 PM
Dirty Howie's Avatar
Dirty Howie
This may be an important step.....
I wound up with a persistant SQUEAK that eventually caused me $150 to
find and fix.......it was a distortated and dirty shock bushing.
DH
Old Dec 25, 2005 | 11:57 AM
GUSTO14's Avatar
GUSTO14
Originally Posted by VetteGuy1999
Hey Guys,
Question: why are the first 2 bushings and the washer on the shaft? Do I have a choice of which bushings to use? please help ready to install.... Jim
Jim, in answer to this question, in case you haven't figured it out on your own,... this is the Bump-Stop for the shock. It's actually one rubber bushing but looks like two until you look up close. I also found it confusing until I removed one of the original shocks.
When you pull you originals off, you will find a similar Bump-Stop arrangement.
Good luck... installation went pretty smooth.
GUSTO
Old Dec 26, 2005 | 10:06 AM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
You should have the two mounting bushings, and a bump stop. All other bushings can be used as weapons to your friends helping out. We have been selling bilstein for years now. They some times come with too many bushings. Why I have no idea, we have a super big box full of not used bushings.
Randy
To Bilstein Install Question
