Question about Hurst replacement shifter.
On the stock shifter there is an "L" shaped pin that drops down into a hole at the front of the shifter into hole on something on the linkage. The Hurst shifter doesn't have this, nor is it mentioned in the install directions. Seems odd that GM would just put something there for no reason, so it has me a bit worried that I am missing something important.
Is this something I need to be concerned about?
I used some silicone adhesive and glued it to the top of the tunnel so it wouldnt get lost. Just pull up your leather boot and silicone it to the rubber dust cover.
BC
I squirted a couple drops of motor oil into the hole and then sealed it with a dab of black silicone to help keep dirt from getting in.
But I have another question.
The rubber lower boot that is held down with the 4 nuts had to be reversed to fit over the wider base of the Hurst shifter. Was I supposed to form that around the base of the shifter somehow? It just basically sits atop the shifter base, but it lets in a lot of noise now that wasn't able to pass through with the original shifter. So did I miss something there that I was supposed to do to seal it around the new shifter?
BC
Yea, what he said! I also put a tiny dab of silicone over that hole just to keep any dust ,dirt or water out of the shifter rod.
http://www.z06vette.com/forums/showt...ht=quiet+hurst
Also try an a/m ****... the stocker with it's plastic center can act as a trumpet.
Yeah, I know, I probably shouldn't have tapped the key down so hard..........
To reduce any slight noise, splitting a tennis ball and covering the stalk helps. However, I specifically chose to merely place my new MOMO shift boot directly over the existing o.e. shift boot. Great sound insulator!
(or what ever its caled, the rod from the shifter to the trans) Or do frc's have the same ones as the later zo6's
turboc5 - Ah! Yes, I can see how that might work out. Thanks. That would be better then just sawing the shifter **** vertically.
I think I have a mind's eye view of something that may work. If anyone of you have ever done ammunition reloading, you probably have had to use a stuck case remover once or twice. Fortunately I have a milling machine, so I think I can make up something that will work in a similar fashion. I just need to drill the key, tap threads in it, then use a standoff (something similar to a gear puller method) to put a screw through it and into the key and hopefully pull it out of the shifter. As long as the screw doesn't strip the threads in the key, it should work. If it strips, then I drill it all the way out as Bill Curlee has suggested.
Worst comes to worst, I take a jig saw to the shifter ****...
BTW, how many people with the Hurst shifter went to the softer springs? I thought I would try to standard ones, but damn, it's getting old having to push that shifter to the right to get into 5th and 6th gear. About 1 out of 5 times I will shift from 5th into 4th by mistake because of the spring tension pushing the shifter to the left.
So, any real drawbacks from using those softer springs? Assuming I can get that blased demon key out, of course....
There wont be any problems making the springs the way you like them. You can pull them all the way out if you want to. The OEM shifter doesn’t have any springs either. There are centering springs inside the trans.
BC
