vararam question
Old Oct 20, 2005 | 06:13 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
VaraRam will give you practically nothing on a dyno. However, it will give you plenty on your 1/4 mile times if you track your car. I do a mod at a time and go to the track. The VaraRam gave me a bunch. Here is my mod progression so far.
Old Oct 20, 2005 | 06:17 PM
Laguna Blu's Avatar
Laguna Blu
Thanks Alot. After another call into The Vette Docs, I will be switching over to the VaraRam. Cajundude, with those nice track numbers what kind of filter are you running with the VaraRam and do you need a velocity stack or not? Also I've seen on the forum the the VaraRam is now shipping with a "new and improved green filter". Any thoughts?
Old Oct 20, 2005 | 06:22 PM
Cajundude's Avatar
Cajundude
No to the velocity stack, I think it is a gimmick. I am running the filter everyone calls crappy. It is the foam one that used to come with the kit. I have no idea about the green one. Also, I've never had water intrusion nor have I had oil, dust, particles, hair, dogs, kitchen sinks, jewelry, coke bottles, or anything else near or on the throttle body inlet. BTW, VaraRam has some of the best customer service I've ever seen personally. I bought a used VaraRam with around 50-100 miles on it. It did not have the coupler or the clamps with it. I called VaraRam and spoke with the owner who happens to live right by me. I told him that I had a used VaraRam and it didn't have the clamps or coupler. He told me to come over to his house and get the stuff. This was at 8:00-8:30 p.m. on a weeknight and to top that, he handed me the stuff and said is free!
Old Oct 20, 2005 | 06:28 PM
yankeevetteconvert's Avatar
yankeevetteconvert
Originally Posted by shurite44
Well I have a little different opinion here. I noticed a fairly significant difference out of the hole. I gained close to a tenth in my 60' time with a vararam.
Here is why I think it helps. When you are drag racing the under hood temps are highest just prior to the green light. If you are using a stock air box it will be sucking 100% hot under hood air. If you are using a vararam all the air will be ambient temp because vararam receives all of it's air from outside the hood. No other CAI can do this.
I bet if you guys go check your time slips or data logs you will see a gain in your 60' times. I average 3 tenths faster with a vararam, and it breaks down pretty close to 1 tenth to the 60' and 2 tenths to the end of the qtr mile.
Old Oct 20, 2005 | 06:40 PM
yankeevetteconvert
Long waits in the staging area realy bring up underhood temps. I had a RM Twinflow intake and opened the fog light area. I monitor intake temp. via a direct hookup and the intake temps went up as soon as I closed my hood. The temps came down by the end of the run but I lost power(do to higher intake temps.) over the first half of the run. After several failed attemps to get the temps to stay at ambient I switched to a TRAP intake. I ran my best time in 86* ambient with this setup. My previous best was at 60* ambient. I also got my best 60 ft. times.
Old Oct 20, 2005 | 08:17 PM
Special K's Avatar
Special K
I'll say this then I'm outta this one. I respect Cajundude and Shurite. But no one has presented any data to support their claims. Jason (Cajundude) has done a good job of documenting his progress. He's forgotten the most important data. Weather. Temp alone means nothing. You need BP, Humidity and DA. DA alone can account for almost .6/.7 loss or gain.
Same goes for Shurite. I know him, he's a friend of mine and he doesn't own a weather station.
The other guys have posted SOP. They don't have a clue of gains or losses. When I was a kid we used to invert the air cleaner cover. You could really hear that engine sucking air and I know it added 100 HP. I could feel it.
You've got an excellent system. You will experience no gain and probably a loss in HP. Good luck to ya and remember I told ya so.
Old Oct 20, 2005 | 08:34 PM
nprsuit's Avatar
nprsuit
[QUOTE=nprsuit]My car 00 vert with MN6, K & N cai, 160 stat and Borla cat back. Best time last August.
60' -- 2.318
1/4 -- 13.637
mph-- 105.10
Put in the Vararam couple weeks ago and went out tonite.
60' -- 2.161
1/4 -- 13.151
mph -- 107.99
2nd Run
60' -- 2.158
1/4 -- 13.175
mph -- 108.04
Maybe it was the drag strip fairy?
Old Oct 21, 2005 | 02:12 PM
beary58's Avatar
beary58
Well I'm curious, most cold air systems give you something. At worse, I've never heard of one taking anything away. Why do you think the Vararam would be different?
Old Oct 21, 2005 | 04:01 PM
shurite44's Avatar
shurite44
Actually I do not have a weather station but I do keep track of the local weather when I go to the track. So I have good data, I predict my dial in within .03 usually. So I definitely have good enough records to notice a three tenths gain.
Old Oct 21, 2005 | 04:32 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Because he's the ANTI VARARAM..........and he said so. Just have to know him to understand him.
Old Oct 22, 2005 | 12:25 PM
BHP's Avatar
BHP
In states like Florida you're drawing hotter air right off the pavement. Not ambient. Your intake is only 12" off the ground.
Several of the guys running at E-Town have stated their cars ran slower with the vararararam. These are serious, hard core racers. They don't go by this 'seat of the pants' crap.
In addition it's lousy construction and lack of filtering capability are detrimental to your cars health.
Hi Gary.
Same issue here in 'Vegas plus it sucks all the dirt off the road. Add to that flash floods and being caught in flooded streets.
Old Oct 22, 2005 | 03:31 PM
Silver98's Avatar
Silver98
You're an ***
Old Oct 22, 2005 | 04:57 PM
  #33
mowton's Avatar
mowton
2 points, then I will let this thread die.
Number 1, if I'm not mistaken, the air inlet for the stock air intake setup, or even the vortech/hurricane etc. is from the bottom. Has everyone cleaned out their radiator space lately. I think I found a dead bird! This point is actually lower than the Fog Light cutouts. The difference in distance from the Fog Light cutouts to where the other intakes reside is probably only 8 to 12 inches.
Number 2, water ingestion issue is discussed per this link
http://forums.corvetteforum.com/show....php?t=1205946
