Transmission Oil?
Old Oct 20, 2005 | 03:07 AM
adamcini's Avatar
adamcini
Default Transmission Oil?
Hi, Could anyone please tell me how much oil to use in a 2002 C5 Auto 4-Speed and what is the best type to use?? Cheers.
Old Oct 20, 2005 | 07:45 AM
Dustie's Avatar
Dustie
Default tranny
I just did a drain & fill yesterday. Picked up a new filter/gasket and refilled with Dexron VI which is now available from GM. Decided not to "power flush" , old fluid nice and pink. I was only able to put about 4 quarts of new fluid in.
Here's some good info...
http://idavette.net/hib/C5diy/c5diy2.htm
Old Oct 20, 2005 | 08:24 AM
AU N EGL's Avatar
AU N EGL
Mobil 1 ATF - synthetic is quiter and smoother
Old Oct 20, 2005 | 09:36 AM
kromberg's Avatar
kromberg
I believe it is about 4 quarts if you drain the fuild and refill.
It is about 5.5 quarts if you do a 'power flush' or a completely empty transmission. You will only be able to add about 4 quarts at first, but once you start the car and allow the transmission to move the fluid through it, you will need to add about another 1.5 quarts.
Keith
Old Oct 20, 2005 | 09:39 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
As an alternative to Mobil 1, I use (and am a forum vendor for) AMSOIL ATF, a Dexron III fluid which meets the requirements for the A4.
Ordering info in my sig. AMSOIL Preferred Customers save about 25%.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To Transmission Oil?
