Harmonic Balancer..
Old Oct 20, 2005 | 11:45 AM
CheM's Avatar
CheM
Default Harmonic Balancer..
This is my first LS1... before this i've owned several ford 5.0 engines....
For the last 3 days my car was making a horrible screeching noise, so i took off the belts, checked all the pullies... everything was fine so i replaced the belts which solved my problems...... while doing this i noticed that my harmonic balancer seems to move a lot.
Is the harmonic balancer suppose to move as much as mine does? On my old fords it was hardly visible... on my new C5 is seems to move a lot when the engine is running....
The engine is very smooth, and has no vibrations however.
Just wondering if its normal or not.
Old Oct 20, 2005 | 12:04 PM
vettenuts's Avatar
vettenuts
By move do you mean "wobble". If it is starting to wobble, there may be problems down the road as they have been known to let go after a while.
Old Oct 20, 2005 | 12:21 PM
CheM's Avatar
CheM
yes i mean wobble.... how much movement should it have?
Old Oct 20, 2005 | 12:28 PM
corvettebob1's Avatar
corvettebob1
NONE!
Either the elastomer is failing or the bolt has come loose, get it repaired immediately.
And pin the crank while it's being repaired to prevent another failure down the road.
Old Oct 20, 2005 | 01:47 PM
vettenuts's Avatar
vettenuts
That is what I was afraid of
Old Oct 20, 2005 | 06:38 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Originally Posted by corvettebob1
NONE!
Don't take this point lightly. I lost a motor at the 2004 SCCA National Championship Runoffs when my harmonic balancer bolt came off. Once you pull the balancer off, the press fit isn't tight enough and the bolt can't hold it on. I found this out the hard way. After the fact, I found out that many SCCA T1 teams put red locktite on the bolt though it isn't called for in the tech manual. Pinning it is the best solution in my opinion.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Oct 20, 2005 | 07:56 PM
CheM's Avatar
CheM
ill be posting a video of this later tonight, blah....
i wish i had more money since this seems like the perfect time to install a cam.....
i can install the balancer myself, but it seems like a pain in the ***.
To Harmonic Balancer..
