LS2 in my C5??
Old Oct 20, 2005 | 09:17 PM
byte_me's Avatar
byte_me
Default LS2 in my C5??
I have read thru the search area some- but I didn't really find the info I was looking for-
Fred Beans sells a complete LS2 for just under $5000. What would it take to slap that into an early C5? 97 to be exact...
I was thinking about a H&C package, different long tubes, gear change from 3:15's but then I said, well I would be close to 5 G's in mods...why not stuff an LS2 in there and start with a 400HP platform...
Any thoughts on this? I am sure at some point I would need to beef up the tranny- but what kind of dollar figure would one be looking at to just drop in a plain old LS2? Professional opinions always welcome- as well as first hand experiences in doing one...
Thanks!
Old Oct 20, 2005 | 09:34 PM
Prosecutor's Avatar
Prosecutor
b
Old Oct 20, 2005 | 10:19 PM
Cary's Avatar
Cary
Thanks!
Why not LS7?
Old Oct 20, 2005 | 10:52 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
I think Phil at Dynotech Engineering offers LS2 engine packages for C5's. I'm not sure what all is involved, but it is possible. Look on their website for their prices.
Old Oct 21, 2005 | 12:00 AM
wamara's Avatar
wamara
Cruise-In II Veteran
DTE posted a few months ago about their LS2 engine package for the C5. Sounded very nice and made very good to great power, depending on emissions and how streetable you wanted it.
Here is the thread:http://forums.corvetteforum.com/show...LS2&forum_id=1
Old Oct 21, 2005 | 01:02 AM
jhong321's Avatar
jhong321
Thanks!
I just put a ls2 402 in mine i got the motor from SDPC for 4,000 this is a short block and also got a cam for $300. then just used my old heads (stage 2) there where a few things that needed to be changed but it was pretty cheap about $100 in parts. slaped it all together and got a tune. put out 450 rwhp and 470 rwtq and this is on a very small cam (226/226 600 lsa112) All i can say is WOW i can do burnouts in 3rd gear at 50mph no clutching needed and not just a little chirp It's a 30 foot line of rubber left on the ground
And it is Smog legal for CA. Sniffter that is.
Old Oct 21, 2005 | 07:12 AM
byte_me's Avatar
byte_me
That's the info I was looking for- I am wondering what something like this would cost for install? Those are impressive numbers!
and as "CARY" posted, the LS7 has not been verified to fit without major modifications and lets not mention price...also the dry oil sump situation is something I am not sure of as where to install an oil can. Plus its twice the price of an LS2! Seems you can pump an LS2 up to these HP numbers rather easily- and it looks as if it drops right in....
Old Oct 21, 2005 | 12:48 PM
boatboatboat's Avatar
boatboatboat
I have a DTE installed ls2 in my 2004 c-5 with an auto. With the 373's and 2800 stall i have right at a 22% drive train loss which left me with 425 rwhp and 400 rwtq. The car drives 95% like a stock car, the cam is very very mild. To me what is the most impressive is the TQ curve. With phil at dte doing the tuning he was able to produce 325 foot lbs of tq at only 3000 rpm. Talk about being in the power band ALL the time... there is NEVER, and i mean never a place in the rpm band where the car bogs down, it's instant GO all the time.
Going with an ls2 in such a new car was obvioulsy not the least costly route, but when I looked at what I was able to sell my ls1 motor for, and then took into consideration the quality of upgrades available for a 4 inch bore ls2 vs the ls1, for ME, it was an easy choice. I am now in a postion to have a stroked 402 with minimal cost, and finaly a 427 in I so desire.
jhong321's Avatar
jhong321
It depends on where you are at I have seen from 1000-2000 for a short block install. I have also seen people with ls2 putting out over 500 rwhp
I think the ls7 is a graet motor but i cost a little to much for what it's worth. The ls2 is pretty much a drop and swap motor. If you really go this way with the ls2 let me know and i can tell you what would need to be done.
Old Oct 22, 2005 | 12:31 PM
fsuforever's Avatar
fsuforever
why not go with the tybrne short block or the slp aluminum shortblock thats what i plan on doing
Old Oct 22, 2005 | 01:11 PM
jhong321's Avatar
jhong321
The ls2 is a aluminum short block strocked to a 402 (6.6 liter). I have read some post about the slp motors not have the support you need.
Old Oct 22, 2005 | 07:02 PM
davisce's Avatar
davisce
Thanks!
This may come a little late for you, but I'm considering a LS1 to LS6 swap in my 1999 C5. I was considering the LS2, but the wiring harness will have to be changed. I was happy about finding that out until I saw a ad in "Corvette Fever" this week from FAST in Memphis, TN (www.fuelairspark.com). Fast makes a complete plug and play wiring harness for LS2 transplant in a C5 SRP in the ad was $906.00.
The LS6 engine on the other hand is a direct bolt in and you can use the same wiring harness. That why I'm considering the LS6 over the LS2 engine.
Just thought I would through that out there for you. . . . hope this wasn't too late ! Good luck on your engine swap.
Cecil
Germany American Corvette Club
Baden-Wurttemberg
Heidelberg, Germany
Hometown: Ft. Lauderdale, Florida
Born: Alexandria, Virginia
Old Oct 25, 2005 | 08:10 PM
Miles in Michigan's Avatar
Miles in Michigan
If you buy an LS2 shortblock, there are only two wiring differences you need to worry about. One is knock sensor location, and the other is cam sensor location. You can extend your own wiring (cut and splice wires) for basically nothing, or buy the plug-n-play adapters for under $60 from racetronix:
http://www.racetronix.com/RX-LS2-CSAH.html
http://www.racetronix.com/RX-LS2-KSRH.html
I don't know what other wiring changes there are if you want to swap an entire LS2 (instead of just the shortblock)... I think maybe the throttle body connector? Anyway, don't pay $900 for a LS2 harness, if you already have an LS1. Much easier (and cheaper) to adapt what you have.
Old Oct 25, 2005 | 08:45 PM
jhong321's Avatar
jhong321
I got my plug and play harness from racetronics. I have even heard that if you put the knock sensors towards the rear of the block you will not have to use the ractronices wires.
To LS2 in my C5??
