Help Wanted (I'm New)
That should get you there. I'll be doing the same thing over the winter along with a 4:10 rear.
Bob K.
btw, update profile so we no what state you are in???
My '01 Mag Red C5 Coupe, A4 has 405 rwhp w/stock heads.
My Performance Mods
1. BPP Vortex Rammer CAI w/Power Duct & Performance Coupler
2. 172 Degree Thermostat w/Fans edited
3. GM 3.42 Rear Diff, replaced factory 2.73
4. Borla Stinger Exhaust w/Quad Tips
5. LS1 Edit, at LGMotorsports
6. ASP UD Pulley Kit
7. Tunnel Heat Shield
8. LG Pro LT Header SS System [mass produced by Borla]
a. 32”Long Tubes
b. 3” Diameter X-pipe
c. 3” Random Tech Metal Matrix High Flow Cats
d. 3” Mid-pipes
9. G5X-3 w/LSA 114 Cam Pkg. ...very streetable
a. GM Timing Chain
b. Required LS1 Gaskets
c. Comp 921 Dual Valve Springs
d. Chromoly Push Rods
e. Titanium Retainers
10. Vigilante 2800 Stall Converter
11. 2004 Z06 Stabilizer Kit
12. Hawk HP Street Brake Pads
13. F*A*S*T* LSX 90mm Intake Manifold
14. G2 NW 90mm Throttle Body
15. B&M SuperCooler Transmission Cooler
16. AMW Red PVC Catch Can
_____________________________
= 405 RWHP
Some of my mods will not apply to your '98 Mag Red M6, since mine is an A4.
BTW, welcome to the C5 Mag Red Club
& thank you for your military service.- 1LT AN [USAR]
