500 RPM idle?
Old Oct 24, 2005 | 11:10 PM
Prosecutor's Avatar
Prosecutor
Default 500 RPM idle?
My car idles at 500 RPM cold. Is this weird? Is this indicatice of a problem? Everything seems to work fine. This has always been the case, to the best of my knowledge. One of my co-workers commented on it today. He has a C5 and said that his idle is higher.
If it makes any difference, my car is a stock 2003 A4 coupe with 48,000 miles on the clock. Thanks.
Old Oct 25, 2005 | 01:26 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
try an idle re-learn
http://forums.corvetteforum.com/show...arn&forum_id=1
Old Oct 25, 2005 | 01:55 AM
Prosecutor's Avatar
Prosecutor
Cool. Thanks very much for the link. Any ideas why my idle would be off? As I mentioned, it is completely stock. I have not screwed with it in any way.
Old Oct 25, 2005 | 06:30 AM
ebubman's Avatar
ebubman
fwiw, i think mine idles @ perhaps 550. bub
Old Oct 25, 2005 | 07:44 AM
C10 JDR's Avatar
C10 JDR
mine too
Old Oct 25, 2005 | 07:59 AM
BadAV's Avatar
BadAV
Mine also idles @ 550.
Old Oct 25, 2005 | 08:20 AM
Wolfmanjohn's Avatar
Wolfmanjohn
525 on a 2004 A4 coupe here. I wouldn't worry.
Old Oct 25, 2005 | 08:28 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Autos idle at 550 +/-, manuals idle higher, I think 850???
Old Oct 25, 2005 | 09:32 AM
chaase's Avatar
chaase
St. Jude Donor '12
I wouldn't worry about it...
Chris
Old Oct 25, 2005 | 09:50 AM
lost's Avatar
lost
If it runs ok, I would suspect the accuracy of the tachometer is off a little, although immediately upon startup it should idle faster for the first few minutes...other factors than can effect idle are a/c on or off, in gear or not. for the record mine idles at 550 in gear with a/c on....
Old Oct 25, 2005 | 11:45 AM
jdetar's Avatar
jdetar
500 idle? what's that!
Old Oct 25, 2005 | 08:59 PM
_Rudy_'s Avatar
_Rudy_
Mine is 800, Z06...
Old Oct 25, 2005 | 09:38 PM
leeman's Avatar
leeman
Default 2004 A4
Mine idles at 500 once warmed up. The lower idle speed indicates that you have a better running car than most forum members. Just Kidding.
To 500 RPM idle?
