few small problems/questions
Old Oct 25, 2005 | 07:03 PM
_Rudy_'s Avatar
_Rudy_
Default few small problems/questions
Hey guys (gals)
First one is occasional backfire on engine start. Normal? Surely my o2s arent bad at 35k. ( I do well to get 15mpg in the city, 27 highway...not too lead footed....)((Z06btw))
Second is a growing rattle around the driver side door switches. Common problem?/fixes? (Im going to pull the pannel off soon and see if i can do anything)
My tranny seems really tight sometimes too, heard this is a common problem though.
Thanks for any thoughts.
Rudy
Old Oct 25, 2005 | 11:30 PM
RoHo's Avatar
RoHo
35k, your due for a set of plugs & it sounds like your clutch is acting up making it hard to shift
What does you clutch fluid look like, take a turkey baster and suck the old fluid out, it will take two or three times over a week to see clean fluid again but I bet you can see the difference in the way it shifts.
Have you ever changed the tranny fluid? if not its time, use Royal Purple Syncro Max- you will feel how much smoother it will be
Old Oct 26, 2005 | 12:19 AM
_Rudy_'s Avatar
_Rudy_
Thanks for the advice. Ill check the clutch fluid tomorrow. Would that require bleeding?
As far as the tranny, should i mess with the rear end too?
To few small problems/questions
