Too Much Oil?
Old Oct 26, 2005 | 06:56 PM
FNFAST's Avatar
FNFAST
Default Too Much Oil?
Any danger in adding too much oil? My car took 7.5 quarts to get the fill line on this oil change. Should I be watching the pressure or anything? The manual says to add an extra quart when racing or competitive driving, but to remove it afterwards, so I think I'm ok. Don't want to cause any damage.
Old Oct 26, 2005 | 07:53 PM
Beezvette's Avatar
Beezvette
7.5 is a lot. Most people put in 6.5 or 7. I put in 7 and it fills it about 2/3 of the way up the cross hatch. I would not put 7.5 in.
Old Oct 26, 2005 | 08:11 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Old Oct 26, 2005 | 11:34 PM
Dave68's Avatar
Dave68
6.5 is perfect, 7 is a bit much, and 7.5 would make me uneasy. Remember, a full crankcase reads halfway up the crosshatch.
Old Oct 27, 2005 | 04:43 AM
l80ous's Avatar
l80ous
When you Yanks say Quarts do you mean Litres?
Old Oct 27, 2005 | 06:06 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Why isn't "full" at the top of the crosshatch? It sounds misleading.
When I changed my oil this past spring, I got the car full warmed up, so the "winter oil" would flow out readily, jacked the rear higher than the front, so al the oil would drain, then let it drain for about an hour. Mine took a little over 7 qts. to refill. Naturally, this included the additional oil that the filter contains...
Old Oct 27, 2005 | 09:54 AM
Dave68's Avatar
Dave68
1 litre = 1.056 quarts
Dave Hill has stated in the past that after a full drain (10 minutes), oil refill is 6.5 quarts. Of course if you jack the rear 6 inches higher than the front and let the oil drain overnight, you may be able to fit in 7 quarts but 6.5 is the average refill volume.
By the way, the factory dip stick marking is misleading. 6.5 quarts does NOT cause the oil mark to reach the top of the cross hatch pattern.
Old Oct 27, 2005 | 10:14 AM
rws.1's Avatar
rws.1
I have read this inconsistentcy with the cross hatches and full before....
The dealership has always filled my '01 to the full mark on the cross hatches....
Old Oct 27, 2005 | 10:54 AM
xlr8shn's Avatar
xlr8shn
No we mean Quarts!
Old Oct 27, 2005 | 01:46 PM
Oldvetter's Avatar
Oldvetter
There are previous threads on this. Appearently the dipstick was changed in later years, so 6.5 quarts don't show as full. On my 1998, 6.5 quarts comes to top of cross hatch.
By the way, raising the rear only drains another 2 ounces of oil. Hardly worth it, but I do it anyway.
Old Oct 27, 2005 | 02:40 PM
Dave68's Avatar
Dave68
No comment........
I believe you are correct about that.
Old Oct 27, 2005 | 03:36 PM
c3andc5's Avatar
c3andc5
Yes, that is too much oil unless you are racing. Believe the 6.5 qts that your owner's manual calls for. I can't comment on the apparent problem with the later C5's dipstick reading because I have a 2000 and 6.5 qts brings me exactly to the top of the cross hatch each and every time.
Old Oct 27, 2005 | 08:52 PM
wolfman04's Avatar
wolfman04
I have a 04 and 7 quarts 2/3 of the way up the cross hatch.
Old Oct 27, 2005 | 11:49 PM
scurry's Avatar
scurry
I find this interesting. I bought my Z about a month ago and checked the oil after I got it home (only had 1500 miles on the current oil change). When I checked it, it read just above the lover mark on the dip stick so I added a quart to bring it up the top of the fill line.... So, is this safe or do I need to drain a little oil?? I've owned a lot of cars in my life and this is the first time I have ever heard that "full" is not the top line on the dip stick.
Old Oct 28, 2005 | 01:04 AM
Dirty Howie's Avatar
Dirty Howie
Dave
I change my oil every 3-4K miles. I now have over 50K miles on the car. EVERY time I put in 6.5 quarts.... and EVERY time it is at the top of the hash marks. This on a 2004.
What do you think......
DH
Old Oct 28, 2005 | 06:32 AM
Joe C's Avatar
Joe C
i had a 2000 coupe and presently have a 04z06. both of these c5's take (or took) 6.75 quarts to fill (top of the hatch pattern, so mid hatch pattern would be about right @ 6.5 qts). i always raise the back up a little higher than the front, and let drain for 20 or 30 minutes. when i took delivery of my 2000 coupe, the oil level was somewhere around 1 inch above the hatch pattern - so much for dealer prep
JoeC
To Too Much Oil?
