Minimum octane that safe for car?
Old Oct 28, 2005 | 07:38 PM
bornagainvetteaddict's Avatar
Default Minimum octane that safe for car?
I read in the manuel that medium grade (89 octane) is ok with the car. Has this been your experience?
Old Oct 28, 2005 | 07:57 PM
99FewteRC5's Avatar
99FewteRC5
i have ran lower octane gas before....did feel a difference.....it didnt ping either...but 91 is the normal
Old Oct 28, 2005 | 07:58 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
People have trouble running 91 octane...but in a pinch, when all you have is 89 it will make your car move, but at a cost of reduced performance, but it will get you home.
Old Oct 28, 2005 | 08:29 PM
J Z06's Avatar
J Z06
You can run the lower octane...but I wouldn't lean on the loud pedal too much.
Like the above mentioned, it could ping. Some have trouble keeping the motors from detonating with 91 let alone 89. It's hit or miss though.
Old Oct 28, 2005 | 08:33 PM
5.0_CJ's Avatar
5.0_CJ
93 if its available to you..
89 is as low as I would go.
Old Oct 28, 2005 | 09:26 PM
boosted_z06's Avatar
boosted_z06
States like Ca only have a maximum octane of 91 and cars run OK.
The PCM's knock learn will readjust so if ping happens it will protect engine by backing timing off so you can use the 89 if you need to
Old Oct 28, 2005 | 10:07 PM
2KREDVert's Avatar
2KREDVert
You won't save money if that is your objective because when the timing retards to compensate, you will lose mileage. You can't get something for nothing here. If you want to run regular, sell the Vette and buy a Toyota.
Old Oct 31, 2005 | 11:17 AM
Saving gas $$$ was the only reason I was wondering. Thats a very interesting point that I will not save any money. What type of millage are you guys getting?
Old Oct 31, 2005 | 02:09 PM
Roc87's Avatar
Roc87
91 is the highest we can get at a "normal" pump. It's 23 miles to where I work, one way, takes nearly an hour mixed city/freeway & I've been getting right at 22mpg, DIC usually shows 22.8 or 23.
Old Oct 31, 2005 | 02:16 PM
Lovin It!!! - C5's Avatar
Lovin It!!! - C5
I'm Runnin' 93 in a 6-speed and getting 33 mpg straight highway. 24 mpg in the morning commute (2 hours on way with 40 minutes of it in <5mph stop and go). Man I love this car!
Old Oct 31, 2005 | 03:16 PM
Ron Dittmer's Avatar
Ron Dittmer
I have experimented with 3 consecutive tanks of 87 octane, and have compared it to regular use of 91 octane. Here are my results.
For Reference.......
- 2001 Corvette Convertible with Automatic & 2.73 axle ratio
- commuting only, no performance driving
- 25 to 50 mph driving speed with 8 minutes of bumper to bumper traffic on average, and around 20 traffic lights, traveling an average distance of 17 miles and driving time of 40 minutes per trip.
Results off DIC.......
- 91 octane 22.5mpg
- 87 octane 21.5mpg (5% loss in gas mileage efficiency)
No pinging, but emphasis on "never hard" on the throttle.
Conclusion........
Driving conservatively, 87 seemed fine on the motor. But with the price of gas at $2.50 a gallon for 87 regular and $2.70 for 91 premium, it's "Break-Even".
Buy Premium.
Old Oct 31, 2005 | 03:45 PM
Kurt_Cobain's Avatar
Kurt_Cobain
Won't the computer just retard the timing?
Old Oct 31, 2005 | 04:35 PM
emf's Avatar
emf
Define "safe".
As many have mentioned, the car will "run" on several grades of gas, including fuels lower than the recommended 91 octane minimum. This is due to 2 key elements that the PCM uses -- the High/Low octane fuel maps, as well as varying knock retard. How effective these things are, ultimately depend on the motor and your driving style. Normally, the PCM is able to sort things out w/o doing too much damage, however that's assuming that a bunch of variables are in your favor.
Personally, I see knock retard and ping when hot w/ 91 octane gas . . . I'm also using shaved heads, a somewhat agressive cam, and slightly advanced timing. KR is only able to take care of so much, which is why I'll end up running something other than 91 when I know that I'll be beating on the car.
So, if we define "safe" as "won't cause irreparable harm" then you'll probably be fine assuming that you don't beat on it. OTOH, if we term "safe" as "won't cause the PCM to go through acrobatics to keep the car running well", then 91 should be the minimum.
Old Nov 1, 2005 | 07:25 AM
Joe C's Avatar
Joe C
i usually ran 89 octane in my 2000 coupe without any problems under normal driving conditions. i have a 2004 z06, and haven't tried anything but 92-93 octane, so i can't comment on that.
Old Nov 1, 2005 | 08:09 AM
David426's Avatar
David426
In Dallas mid grade (89 octane) is 2.49 a gallon. 93 Octane runs .10 cents more at 2.59 a gallon. So you save a grand total of 2.00 a tank. And if you consider what Ron just posted.. A 5% loss in efficiency or gas mileage on the cheaper stuff. The net result is about a .20 cent savings per tank full!!. If you carefully budget your income. I think you can make room for the premium gasoline. If you cannot afford an extra .20 cents a week I can arrange to send you a check once a month for .80 cents just send me a message...
Old Nov 1, 2005 | 09:49 AM
VetteDrmr's Avatar
VetteDrmr
I think the consensus is that, for the LS1 engines, the net difference between using various grades of fuel is so close as to be lost in the noise.
Now, on my '94 Z-28 (LT-1 engine, MN6), I found that I got the best mileage with 89, but even then it was just a small amount. Then as the engine got more miles on it (175K+ as of today), the octane needs slowly crept upwards. I'm thinking it's got some carbon buildup that I'm not going to be able to get rid of other than a full teardown. So she gets 91-93 octane fuel now as well.
HTH, and have a good one,
Mike
Old Jan 31, 2006 | 10:25 PM
JACK EPPERSON's Avatar
JACK EPPERSON
Default Gas
I HAVE PEOPLE SAY WHAT KIND OF MILEAGE DO I GET. I GET AROUND 29 TO 30 ON THE HIGHWAY. IN TOWN T GET AROUND 22 TO 24. THEY ALSO SAID LOOK AT THE PRICE YOU PAY FOR GAS. I TELL THEM I PAY ABOUT $2.00 MORE THEN YOU DO,AND LOOK WHAT YOU HAVE TO DRIVE. STAY WITH 91 OCTANE.
Old Jan 31, 2006 | 10:35 PM
Rhode Warrior's Avatar
Rhode Warrior
I've never used anything less than 93, sometimes I use 94 when I can get it.
To Minimum octane that safe for car?
