the theory is that the 4 unshrouded electrodes give a more uniform flame front and more compleye combustion increasing the energy released in each cylinder ....
Is it real... don't know
An explosion is not an explosion. A lot of Research is done by oil companies and fuel additive companies to try and obtain a more uniform flame front in the combusiton chamber to increase complete combustion....
Incomplete combustion is why catylitic converters exist and so many Forum members worry about passing a sniffer (SMOG) test.
The more uniform the flame front, the more complete the combustion ... the more power and less residual hydrocarbons.
Racers have been using "cutback" plugs for years to increase horsepower. That is the theory behind the +4's 4 cutback electrodes to unshroud the spark and permit more complete combustion.
there's nothing better than a good old fashoned copper plug for performance! that's why I'm using NGK TR-55 plugs, and the NGK plugs only cost about $13.00 for the set, as opposed to the Bosch +4's that cost about $13.00 each!
Whether it works is another matter...
Show me one piece of independent research, which gives even 1 HP...I don't believe it..sorry..
I have never seen any documented evidence, or proof, that spark plugs, from different manufacturers even, of the proper physical size and length, heat range and gapping, provide any discernible performance difference over another, other than longevity due to material composition. That is why I chose to go with the GM 41-985 Iridiums....long life without having to change them out frequently. Each to their own.
Ed
I replied to a similar post a while back so if you do a search under tech for Bosch plugs or my name you'll see it. In a nutshell, it's all marketing hype generated to push a new product. The design has been around for a long time and used as a way to increase plug interval changes in huge industrial engines mainly used in the gas fields to generate electricity. Save your money.
I’m thinking…. If you believe that electricity takes the path of least resistance, then you would also have to believe that each of the 4 electrodes would have to be precisely the same in both mass and gap. If they are not the same, the plug will fire on the least resistant electrode each time.
Can you really get an extra 5-6hp by installing a set of Bosch Platinum + 4 spark plugs?
yes, but only under this condidtion: that your car currently suffers from pre-ignition. The Bosch +4 are a slightly colder plug than the factory installed plugs and can correct a "problem". But if you don't have a "problem" that needs corrected, then IMO they won't make any difference.
