rocker panel removal
Old Oct 29, 2005 | 01:57 PM
_Rudy_'s Avatar
_Rudy_
Default rocker panel removal
Anyone ever replaced a rocker panel before? It looks like the quarter has to come off to get it on?!? I was attacked by a parking deck
Luckily dad owns a body shop that specializes in vettes, so they will do the work, I was just curious...
Old Oct 29, 2005 | 02:02 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
what exactly is a parking deck?
Old Oct 29, 2005 | 02:56 PM
_Rudy_'s Avatar
_Rudy_
Its a bad, bad thing. stay faar away
Old Oct 29, 2005 | 04:16 PM
RPOZ4Z's Avatar
RPOZ4Z
can you describe one so I'll know what to run from?
Old Oct 29, 2005 | 06:37 PM
SpeedyZ's Avatar
SpeedyZ
I would patch that! Rockers are glued on the frame. They are glued to the bottom of the frame and come all the way around to the top of the frame and glued again. They extend all the way up to the top of the door and glued all the way up there too. Plus on that FRC it makes it even harder because you can't get to the bolts to remove the rear fender. The fender has to be removed before you can remove the rockers. Patch that thing!
Old Oct 29, 2005 | 07:18 PM
edensknight's Avatar
edensknight
Old Oct 29, 2005 | 07:28 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
That's a simple patch repair.
Old Oct 29, 2005 | 07:29 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Major PITA to remove. In most cases they will get destroyed in the removal process and you'lll need to buy new ones. Just patch them up and repaint.
Old Oct 29, 2005 | 08:27 PM
SteveDoten's Avatar
SteveDoten
http://forums.corvetteforum.com/show...00&forum_id=53
there are 2 people in this thread that have the info on rocker replacement(not saying that's what you need)
a new rocker is <200 from local gm dealer
there's another guy on the boards that owns a body shop and can help getting you in the right direction on how to fix the rocker(ie: materials/process needed)
Old Nov 1, 2005 | 07:47 PM
_Rudy_'s Avatar
_Rudy_
Thanks guys, i forgot to add a subscription to this thread. I talked to my dad's bodyman today, he said it pays 6 hrs to replace, which is a lot of time for something that "minor". We already have the new part, but I have to find a week I can take the car home. I think he's gonna patch it. Id rather dad do it cuzs he like the grand master at fiberglass work but he's KOed from cancer. That stuff sneaks up pretty bad
Ill let yall know how it goes, Cary is a hell of a bodyman, and the painter rocks too, so she'll be fine Im still pissed that i hit the deck to begin with.
Oh, and as for that description, just stay far away from anything that has a lot of parked cars around it, and anything with non horizontal concrete (less its banked of course
Old Nov 1, 2005 | 08:36 PM
TheLaserShop's Avatar
TheLaserShop
Easy fix. Will suffer utter failure trying to get it off. They say to use a heat gun but the heat also delaminates and pretty much destroys the SMC. Doesn't look like its all the way through. Paint will be the hardest part. Evercoat makes a filler for SMC.
Old Nov 2, 2005 | 12:37 AM
_Rudy_'s Avatar
_Rudy_
Actually, it is all the way through. There is a hole on the side near the back, and the bottom of the rocker is split. The damage is actually worse than the picture shows. Thats why dad went on and ordered a new rocker. I think Cary may plan on sectioning in the damaged area. I know that would be easy enough with straight fiberglass, but Ive not messed with SMC any, so I have no clue. Thats why I'll leave it to the pros.
Old Nov 28, 2005 | 02:57 AM
_Rudy_'s Avatar
_Rudy_
Ok guys:
Got the old rocker off (completely destroyed). Looks like to do a rocker job completely right, you would have to take the quarter off (dunno what all that takes), and the fiberglass cover for the door pilar, as the rocker goes behind both. Cary (the bodyman) was able to trim the front of the new rocker enough that he could slide it under the door pilar. He was able to slide the back under the quarter too, but it split a little. No biggie there, simple patch up. He said this was one of the hardest repairs he's had to do because of how the car was built, but i think he was nervous cuz it belongs to the owners. Whatever, i trust him.
here are a few pics:
Old Nov 28, 2005 | 08:12 AM
TheLaserShop
Ok guys:
Hate to say I told you so. Would have been much easier to fix the hole. I bet the old rocker is in a thousand peices. Not tryng to be a smart ***. Looks like it will work out OK. Did he ever take the rear fender off?
Old Nov 28, 2005 | 10:17 AM
_Rudy_'s Avatar
_Rudy_
Well, I wish I had a better picture of the damage. It actually put a hole about two inches in diameter in the rocker and had the rear section behind the damage pushed in. The rocker was actually split across the bottom. They were worried about being able to get to the back of the damage to correctly fix it, and since the car is so new, they wanted to fix it right. He was able to slide the new piece in behind the quarter panel without removing it.
here's the old one:
To rocker panel removal
