AC Tensioner Pulley
Old Nov 1, 2005 | 12:41 PM
thevelvetglove's Avatar
thevelvetglove
Default AC Tensioner Pulley
Need to replace the ac tensioner pulley on the bottom. There is one bolt holding it on, with what looks like a pipe almost over the bolt. So I have a few questions:
1) What is the size of the bolt
2) How do get a torque wrench on it
3) How mcuh torque
4) How do I get to it ..top or bottom
5) How to I get to the bolt?
Should I even try this myself
Old Nov 3, 2005 | 12:50 AM
Bounty Hunter 6's Avatar
Bounty Hunter 6
Yes, you can do it. I assume you have an A4, because the Mn6 do not have these pipes over the bolt. The size is 15mm.
There is a small black clip that is holding the two pipes together, simply remove this and you can spread the pipes apart to get the socket in between them and on the bolt. Best of luck!
Old Nov 3, 2005 | 10:57 AM
xlr8shn's Avatar
xlr8shn
I have replaced my A/C tensioner pulley from under the car with a socket extension and a 13mm or was it 15mm socket...
Mine is an M6 though... Not tough.
Old Nov 3, 2005 | 11:41 AM
JTS97Z28's Avatar
JTS97Z28
I just replaced mine 2 days ago although my car is an M6. It was pretty simple. Let the belt lay there but leave it on the rest of the pulleys as that can be a pain to get back on. Unbolt the tensioner and bolt the new one on then put the belt on.
Old Nov 3, 2005 | 12:37 PM
thevelvetglove
thanks guys I will try it this weekend and let you know. I brought the parts from Fred beans what a deal!
eBy the way a4 a6 what is that ? I have a c5 2000 corvette coupr
Old Nov 3, 2005 | 12:38 PM
thevelvetglove
any idea on torque?
Old Nov 3, 2005 | 05:29 PM
rws.1's Avatar
rws.1
A4 Automatic 4 speed transmission....
M6 Manual 6 speed transmission
Old Nov 3, 2005 | 05:46 PM
thevelvetglove
I have a 2000 C5 coupe wiht A4 transmission. I did not know there were two types
Old Nov 3, 2005 | 06:55 PM
thevelvetglove
does anyone know the torque on AC tensioner pulley? Thx
To AC Tensioner Pulley
