Brake Pads - Replacement Indication?
Old Nov 1, 2005 | 08:17 PM
RedC5's Avatar
RedC5
Default Brake Pads - Replacement Indication?
I have 35K on the C5 and the last time I looked, the inner pads on both fronts were quite thin. Want to get the most out of them but do not want to go to long. Seems there is no wear indicator on the inside pads, is it there? The outers still have pad left. What do most of you do, replace before any indication or ride it out till they are totally worn?
Old Nov 1, 2005 | 09:32 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Besides visually inspecting the pads and comparing them to the meat on new ones...
I do believe there is a pin which looks like a retainer clip... once the pad is worn down, the pin should make contact with the rotor and cause a squeal.
Old Nov 1, 2005 | 11:10 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Ride it out and you will need them at the most inopportune time and probably need rotors also. I would not run them less than .20" of material left.
Old Nov 3, 2005 | 06:51 PM
RedC5's Avatar
RedC5
I hear nothing at this point....I am going to change out next week just in case.
Old Nov 3, 2005 | 09:55 PM
chocoholic's Avatar
chocoholic
FWIW, I'm fairly confident that the stock pads do have wear indicators, but as they'll be on the trailing edge on the inside, it's not always that easy to see. Still, it only takes a couple of minutes to jack up the car and pull the wheel off to properly inspect them.
As John says, don't wait until you hear the noise, as you'll be replacing more than pads at that point. Pads last as long as pads last. You'll have to look yourself to see how yours are doing.
Old Nov 3, 2005 | 10:21 PM
LoneStarFRC's Avatar
LoneStarFRC
Good move! Mighty cheap insurance for something so important. Me? I got a little over 90K on my first set (of course your mileage may vary)
To Brake Pads - Replacement Indication?
