Oil filter question..help...
Old Nov 2, 2005 | 11:18 AM
dbvettez06's Avatar
dbvettez06
Default Oil filter question..help...
Can anyone hook me with info on which filters are the best for the Z...I know its been discussed a lot
Old Nov 2, 2005 | 11:36 AM
jrose7004's Avatar
jrose7004
I like that K&N Oil Filter!
Old Nov 2, 2005 | 12:03 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
It has been discussed a ton and you will get a ton of different answers.
I race both 1/4 mile and road courses and the GM ones work just fine. I order them at a case at a time from FredBeans (I probably use that amount per year).
||--Genuine GM UltraGuard UPF 44 Oil Filters--
25329389 - UPF 44 Oil Filter
Must order in cases of 6 @ 47.99 shipped!!
http://forums.corvetteforum.com/show....php?t=1207414
Old Nov 2, 2005 | 12:27 PM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Read about the new Nano filters offered by Amsoil over there to the left.
Old Nov 2, 2005 | 12:47 PM
SGT. PYLE's Avatar
SGT. PYLE
HP1007
Old Nov 2, 2005 | 02:31 PM
2kbluestreak's Avatar
2kbluestreak
How do you know? Really, as long as no problems are experienced with any filter, how do any of us know how good they are or how well do they work. It's possible that a filter could have an internal leak and not really "filter", as well it could get stopped up early and go on bypass. A couple of years ago an engineer who got screwed by a Fram filter realized the above and methodically cut up several brands of filters to see what they were like inside. Try going to http://members.xoom.com/minimopar/oilfilterstudy.html or http://www.scuderiaciriani.com/rx/oil filter study/.
In short, he thought the standard AC filter was pretty good, while a lot of others were very cheaply made.
Old Nov 2, 2005 | 11:24 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
The actual source of a lot of oil filter testing is on this link: www.oilfilterstudy.com
As mentioned above, AMSOIL just released a totally new line of filters with nano technology that supposedly has near 100% efficiency while maintaining excellent flow. I just read about them yesterday.
The part number for the C5/Z05 is EAO32.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 22, 2005 | 04:32 PM
SamirD's Avatar
SamirD
I've been reading a bunch about this today and have looked at three different studies for three different applications. And I was shocked at how poorly some filters I've used tested.
But the one conclusion I've walked away is this: Purolater Pure One seems to regularly be at the top or very near the top of all filters. That is, unless they've cheapened their design since the study. If so, then I'll just stick to the Amsoil filters and oil.
Old Nov 22, 2005 | 04:35 PM
Z06Doug's Avatar
Z06Doug
Amsoil filters, GM filters, K&N, and the Mobil1 are all good filters, any of them will work fine.
Old Nov 22, 2005 | 05:05 PM
Pumba's Avatar
Pumba
I have settled on Mobil 1 Extended Life filters, in fact, I use two of them.
I have just received my annual oil analysis from Blackstone Labs. They rate my oil as being in A+ condition. They commented on the low level of insolubles, and how my filtration system is doing a great job. And because I am running dual filters in parallel, I have the best of both world's, small particle filtration without restricting the flow of oil to the engine.
Good luck on your decision.
Old Nov 22, 2005 | 05:21 PM
rws.1's Avatar
rws.1
Mobil 1 extended life
Old Nov 22, 2005 | 07:43 PM
Patman's Avatar
Patman
I like the K&N oil filters too, and I have the oil analysis results to show they are doing a great job. On a high performance engine that is driven hard, it's much more critical to have a free flowing oil filter like the K&N, compared to one that filters out the smallest of particles like the Mobil 1.
Old Nov 22, 2005 | 10:10 PM
Dave68's Avatar
Dave68
K&N makes a fantastic filter.
To Oil filter question..help...
