Trouble Code Question
Old Nov 4, 2005 | 04:58 PM
AD2VET's Avatar
AD2VET
CI 2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '09-'10
Default Trouble Code Question
Does anyone know what a B2265H DTC means. I looked it up and it says: "Horizontal Position Sensor Fault DCM-R". I think it may be referring to the right door control module but I'm not sure what that it. TIA
Johnny
Old Nov 4, 2005 | 08:28 PM
RonJ's Avatar
RonJ
I think this is the sensor in the RS outside mirror.
If you change the mirror adjustment, will the mirror return to it's original setting from memory??
RonJ ...
Old Nov 5, 2005 | 10:04 PM
Slammed..'s Avatar
Slammed..
My codes say this is a vertical position not horizonal,try the switch for up and down,i think your switch is bad.
To Trouble Code Question
