C5 Pinging
Old Nov 5, 2005 | 06:14 PM
Long EZ's Avatar
Long EZ
3rd Gear
Default C5 Pinging
I have a 2000 C5 coupe, automatic, with 50,000 miles. Recently, it started pinging under little or no acceleration. I have replaced the 4 O2 sensors, fuel filter & air cleaner, & used top end cleaner. The plugs seem to be in excellent condition. Fuel pressure is good and the injectors pass the 400ms/fuel pressure drop test. The computer shows no codes. Anybody have a sugestion as to what I should check next?
Old Nov 5, 2005 | 08:30 PM
ErnieN85's Avatar
ErnieN85
Have you tried different gas?
Recently I got some bad stuff.
I have heard of puting diesel in the wrong tank (station).
Yes it really happened!
Old Nov 5, 2005 | 09:44 PM
rws.1's Avatar
rws.1
If it wasn't for the little or no accelration I'd suggest you check your exhaustsystem for a loose hanger ..
Under heavy acceleration most C5's have a rattle that can be misdiagnosed for pinging that originates in the stock H pipe.
Old Nov 7, 2005 | 05:21 PM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
Whether or not it's bad gas, or whatever, I got tired of fooling around with mine and simply backed the timing off about 4 degrees and viola, no more "ping". Vette still runs like a scalded cat too.
Old Nov 7, 2005 | 05:36 PM
ErnieN85's Avatar
ErnieN85
Curious minds want to know.........how do you back off the timing on a LS- engine?
Old Nov 7, 2005 | 05:39 PM
BadAV's Avatar
BadAV
The catalytic coverters might be clogged.
Old Nov 7, 2005 | 06:05 PM
ztron's Avatar
ztron
I too am having a pinging or a jingling type sound in my 99 coupe (stock) I have just taken it to a muffler guy and he couldn't find any thing in the exhaust system.. it kinda sounds like it is coming from under the motor , I was under it also with the muffler guy,, we are both puzzled.. any suggestions.. will a blocked cat cause it to ping/jingling..?
Old Nov 7, 2005 | 06:18 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
10% mix is ok by fed standards at all gas stations .
One of our customers that owns a gas station told me that.
Randy
Old Nov 7, 2005 | 08:47 PM
rc51racer's Avatar
rc51racer
Default rws.1
Thanks for the info about the rattling of the stock H pipe. I got into it the other nite with a GSX-600R. He would not leave me alone so I finally gave him some back. I noticed when I was in 2nd or 3rd gear at about 4000-6000 RPM that I heard what I thought was pinging. I have never ran my C5 this hard that long. It was about a mile or so, only at the higher rev's. Is there anything I can do to the stock H pipe to cure this sound? I have a 99 coupe M6.
Old Nov 7, 2005 | 09:06 PM
ErnieN85's Avatar
ErnieN85
Randy
The stuff i got acted more like 50% It sure wasn't 93 octane anymore
Old Nov 7, 2005 | 11:41 PM
MagikDraggin
Cruise-In V Veteran
With a Predator, or similar hand-held 'tuner'.
Old Nov 8, 2005 | 08:03 AM
ErnieN85's Avatar
ErnieN85
Darn never thought of that! Guess I'm stuck on the old way............. thought I went past that years ago.
Old Nov 8, 2005 | 08:52 AM
David426's Avatar
David426
Loosen the distributor and turn clockwise about 1/4 of an inch. Use a timing light and make sure to chalk the timing pulley so it can clearly be seen.
Old Nov 8, 2005 | 09:00 AM
Slammed..'s Avatar
Slammed..
I agree with the others,it probably not pinging,if it was pinging that bad,your PCM would switch over to the "low octane tables",this reduces the timing quit a bit,from 28* down to 18* - 21* iv'e seen on my scanner.
If your pinging in the low tables,theres something pretty wrong.
Your using at least 92 octane i'm assuming.
Old Nov 8, 2005 | 10:24 AM
ErnieN85's Avatar
ErnieN85
David a Ls doesn't have a distributor!
Old Nov 8, 2005 | 12:11 PM
David426's Avatar
David426
Yep, nor does an LS have points or a carberator
It was meant to be a joke
Old Nov 8, 2005 | 12:20 PM
ErnieN85's Avatar
ErnieN85
Your forgiven! Some of us old timers don't know about that yet.
To C5 Pinging
Old Nov 8, 2005 | 04:27 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Old Nov 8, 2005 | 09:45 PM
LoneStarFRC's Avatar
LoneStarFRC
BTW, don't forget to remove and cap the vacuum line going to the vacuum advance canister on the distributor before you start.
Old Nov 8, 2005 | 11:17 PM
daveydc5's Avatar
daveydc5
YOu sure it isn't shifter rattle? Do you have an AM shifter?
