A/C question
Old Nov 6, 2005 | 12:31 AM
MassaRusty's Avatar
MassaRusty
Default A/C question
I just got a 1999 FRC that has the manual air conditioning controls. When I try to change the blower between floor, floor/forward, and defrost positions, nothing happens. No matter what position that **** is in, the air still blows the same place. Has anyone run into this problem before? Again, this is the manual control A/C.
Old Nov 6, 2005 | 10:58 AM
MassaRusty's Avatar
MassaRusty
ttt
any help is appreciated
Old Nov 6, 2005 | 04:12 PM
Shylor's Avatar
Shylor
Well obviously it sounds like either the valve is stuck or your switch needs replacing.
Old Nov 7, 2005 | 12:47 AM
Wisdom's Avatar
Wisdom
That fuse trick only works on the automatic A/C controllers?
Old Nov 7, 2005 | 04:50 AM
StuandJoy's Avatar
StuandJoy
If the manual ones are the same as mine then check the vaccuum hoses under the battery. Could be corroded.
Old Nov 7, 2005 | 05:30 AM
Midwest Vette's Avatar
Midwest Vette
I had the same problem.
Old Nov 7, 2005 | 08:27 PM
MassaRusty's Avatar
MassaRusty
Thanks, I will check under the battery. Never would have thought to look there.
Old Nov 7, 2005 | 08:55 PM
Jharms's Avatar
Jharms
I had the same problem with my 98. There was a problem with the battery causing it to leak (known issue I think). Mine was the dual zone AC but the vent switch controls didn't work correctly. I took it into the shop for the repair because I had an extended warranty. They told me that it wasn't covered under warranty so I had to pay to replace the metal vaccuum hoses. It's been a long time ago, but I recall it costing me a bit over $500.
Old Nov 7, 2005 | 09:28 PM
berryj's Avatar
berryj
I got worked over at the stealership myself for this same problem. That's when I bought a dry cell battery.
To A/C question
