Resetting oil life
Old Nov 6, 2005 | 09:48 PM
wreakhavoc's Avatar
wreakhavoc
Default Resetting oil life
I never had a problem with this before. The manual says
"With the ignition on, press the TRIP button so the
OIL LIFE percentage is displayed.
Press RESET and hold for two seconds. The word
RESET will appear, then OIL LIFE 99%"
but now the word "reset" does not appear, it just says "_ _ _ %" and will not reset. Each time I start up the car I still get the "change oil now" message.
Old Nov 6, 2005 | 09:58 PM
nmbsun's Avatar
nmbsun
I dont know if this will help but once after an oil change I reset the oil life with the engine running and got the _ _ _ %. I turned the engine off and turned the key to on but did not crank the engine and reset the oil and it went to 100%...
Always reset it with the engine off...
Old Nov 6, 2005 | 11:18 PM
MY1STPEWTER's Avatar
MY1STPEWTER
You might try this method, turn the key all the way without starting the engine and press the gas pedal 3 times.
Old Nov 7, 2005 | 01:38 AM
striper's Avatar
striper
I believe it's four times, and then turn key off and then back on.
Old Nov 7, 2005 | 04:02 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
It's 3 times but after you are done you have to get out of the car and run around it screaming Corvette Rocks!!!
seriously I have had it not say 100% and just have the blanks but usually when you turn it off and on it will be right
Old Nov 7, 2005 | 12:41 PM
VetteDrmr's Avatar
VetteDrmr
Old Nov 7, 2005 | 01:11 PM
Lovin It!!! - C5's Avatar
Lovin It!!! - C5
ROFL, I love the part about running around the Vette screaming. I'm gonna try this method tonight when I get home.
I Love this place!
Old Nov 7, 2005 | 03:13 PM
2EZ2BQK's Avatar
2EZ2BQK
From: NorCAL Live your passion--why wait, you ain't getting any younger
This was the method I used Saturday.
100% Life showed up immediately following the ignition cycle back to Off/On
Old Nov 9, 2005 | 07:06 AM
wreakhavoc's Avatar
wreakhavoc
Thanks, that did it.
Old Nov 9, 2005 | 04:02 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Did you have to run around the car screaming CORVETTE ROCKS!?
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To Resetting oil life
