loose harmonic balancer
Old Nov 8, 2005 | 06:35 PM
joelshaw's Avatar
joelshaw
Navigator
Default loose harmonic balancer
Has anyone replaced the bolt on the Harmonic Balancer on a C5 without removing the rack and pinion? My '98 threw the AC belt. On further inspection, it turst out that the bolt on my harmonic balancer had come lose. I managed to tighten it back up, but a few weeks later it came lose again. I built a wrench so that I can get sufficient torque on it. However, the manual specifies using a new bolt. Unfortunately, I can't get the old one out b/c of the rack and pinion. I think I might be able to lower the front cross member and get it out, but I don't really want to disconnect the steering column and risk blowing up the air bags, especially if I still won't be able to ge the bolt out.
Suggestions?
Has anyone tried putting a whole bunch of Loctite in there, using the old bolt, and praying?
Any suggestions would be appreciated.
Old Nov 8, 2005 | 07:04 PM
vettenuts's Avatar
vettenuts
There are so many things that can go wrong here, I would simply suggest pulling the rack and doing it per the manual. You have been lucky thus far since no damage has occured. Pulling the rack is not that bad, I was concerned going in but it was actually quite easy. Go to LS1HOWTO.com and check the cam installation in a C5. You will see what needs to be done to get at it. Also, if the bolt is loose, I would consider putting on a new damper since with higher mileage cars they can be an issue. If the bolt is loose, the damper may be already turning on the crank shaft. Don't use loctite, you may end up with bigger problems down the road IMO.
Old Nov 8, 2005 | 07:08 PM
LoneStarFRC's Avatar
LoneStarFRC
Good advice.
Old Nov 8, 2005 | 08:29 PM
chriswtx's Avatar
chriswtx
Also while your in there just pin the crank like the supercharged guys do and you will have no more problems...
Old Nov 8, 2005 | 08:40 PM
robvuk's Avatar
robvuk
Isn't GM doing anything for this problem, even after the warranty is up? I suppose that's wishful thinking, but it SHOULD be covered since it's clearly a factory defect. Regardless of how long it's been.
Old Nov 8, 2005 | 08:55 PM
Lotus77777's Avatar
Lotus77777
Be carefull or you'll end up in my situation
http://forums.corvetteforum.com/show....php?t=1227076
Mike
Old Nov 9, 2005 | 04:12 AM
joelshaw's Avatar
joelshaw
Navigator
Alright. Because of your advixe, I think that I am going to move the rack and pinion and replace the crank bolt. I don't think that I am going to replace the harmonic balancer unless I find a good deal on one before this weekend.
Hopefully it will work... otherwise, I think I will chalk it up to bad luck.. like my Buelle I broke the crank in half on, or the Tahoe that I broke both half shafts on.. or the 240Z i put a small block in and broke the drive shaft on... or the VW I burned a hole in the cylinders on, or the Fiat I broke the valves on... Or the mazda's that I have burned up head gaskets on...
I guess I just have to try to fix it. Hopefully not over and over again...
I appreciate the help. I just hope that I am able to fix it correctly. Thanks for all the advice, and I will write back about how it goes.
Old Nov 9, 2005 | 05:55 AM
vettenuts's Avatar
vettenuts
Before you start, make sure you have a degree wheel to measure bolt rotation, Autozone has them. Also, pick up a set of vacuum caps and use them to cover the two PS hoses that you remove from the rack so you won't lose much fluid. Make sure the wheels are straight before you start and use some bungee cords or something to hold the steering wheel from rotating. A couple of clean rubber corks will also help keep the fluid in the PS box while you rotate it out of position.
Old Nov 9, 2005 | 04:09 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
First, you do have to remove the steering rack to do this. If you are concerned about the airbags, pull the fuse (#16 I think) and disconnect the battery. Second, I would caution you against reusing the harmonic balancer. Its press fit is loose now and even with a new bolt, you won't be able to hold it on. I lost a motor this way...
If you do not key the new bolt, I would recommend adding locktite. I didn't, and I reused the old harmonic balancer not knowing about this problem - and though we did use a new bolt and followed the service manual procedure exactly, my balancer came off on the track at over 5000 rpms... and did I say I lost a motor this way?
After I lost my motor, I talked to several other SCCA teams and found that after an engine rebuild, they all do use locktite to help hold the bolt in there. Personally I don't think the worry about the bolt getting stuck in the crankshaft due to the locktite is a little unfounded. The two large bolts on the brake caliper bracket get red locktite and I take those on and off all the time without problem.
Good luck.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To loose harmonic balancer
