help with headers
Old Nov 7, 2005 | 01:03 PM
brake dust's Avatar
brake dust
Default help with headers
can anyone tell me how hard it is to put on a set of long tube headers .......thanks
Old Nov 7, 2005 | 01:31 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
They are not difficult at all. That said depending on what brand you use, the difficulty will change as they are not all the same. If you are mechanically inclined you can do the install with no problem.
Bob
Old Nov 7, 2005 | 02:55 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
My install page..........
http://temp.corvetteforum.net/c5/30s..._EXHAUST.shtml
Old Nov 7, 2005 | 07:41 PM
FASRIDE's Avatar
FASRIDE
Just installed my Kooks, it went pretty good. Watch out for a couple things though. First of all on my installation directions said to loosen the alternator bracket, we ended up taking it all the way off. one bolt on there that is a SOB to get to, will take some time. Also watch out for temp sensor on drivers side, we broke the plastic connector end off when we tried to force header in from top. But that was before we took alt. bracket off. Follow the directions and you should be fine.
Old Nov 7, 2005 | 08:08 PM
brake dust's Avatar
brake dust
Default thanks for all the help
i feel much better...
Old Nov 8, 2005 | 07:57 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
Here's a real good (w/ photos) account of installing some QTP Tri-Y's:
http://forums.corvetteforum.com/show...um_id=1&arch=1
Old Nov 8, 2005 | 02:25 PM
gppracer's Avatar
gppracer
Just did mine this past weekend.There Are 2 hard bolts to get at.The driverside back header bolt. Rear of motor,the bolt holding air tube on back of motor.That need to be changed for LG headers for 97-2000 model years.The rest was easy. I loosen the starter and passenger side went right in.driver side went in in easy from botton.I left alt bracket on.
BEWARE OF OIL TEMP WIRE ON DRIVERS SIDE!!! It is on top of oil filter.I didn't see it when under car and pulled wire out of connector.You should unplug it .
PS Does anyone know where i can order a new oil temp sencor connect with wires to splice back to my orginal?
Good luck
Greg
Old Nov 8, 2005 | 05:22 PM
davidfarmer's Avatar
davidfarmer
I've had to remove both the alternator AND the starter on some cars to get clearance. Sometimes the bottom bracket (that bolts to the bellhousing) doesn't line up properly, and you need to be comfortable cranking it over with ratchet straps etc. If you go ahead and get everything out of the way, the actual headers go on quite easily.
Old Nov 8, 2005 | 07:58 PM
bcseitz's Avatar
bcseitz
I'm about to find out how easy the header install will be this weekend.
My Stainless Works headers are at JetHot right now and I will pick them up Friday. Along with the header install, Random Tec. high flows and their X pipe.
I'm going to use the "LS1 HowTo" instructions for LG longtubes for a guide.
I'm all ears for additional tips!
[IMG][/IMG]
(See sig for current mods)
Old Nov 8, 2005 | 08:21 PM
smask04c5's Avatar
smask04c5
Really not too hard at all. Remove the alternator and bracket completely. Make sure car is either on a lift or about 24 inches high on jackstands.
Old Nov 8, 2005 | 10:35 PM
REDLYNER's Avatar
REDLYNER
I will be doing the same install this weekend. I bought a Dynatech header/cat/x-pipe kit last week (still waiting on delivery) and I will be using the LS1-how-to also. I just hope I have all of the right tools!
After this weekend there will be a few more meaner vettes on the road!
Good luck to you guys!
Old Nov 9, 2005 | 06:33 PM
gppracer's Avatar
gppracer
Don't forget to buy 2 gaskets for flanges at the cat- bac.My set of LG headers didn't come with them. The old ones came apart.Auto Zone & Murrays Don't keep these instock.
Greg
Old Nov 9, 2005 | 06:53 PM
JimK-98's Avatar
JimK-98
Had more problem with getting the 02 sensors to quit sending in check engine light than anything. Get ready for a loud car when u put the gas peddle down.............Have fun
Old Nov 9, 2005 | 08:36 PM
slolane's Avatar
slolane
CI 7-8-9 Veteran
St. Jude Donor '07-'08 & '12
I did my Dynatech suppermaxx system with no help in one day. Just follow directions step by step and you will be fine. You will love the sound.
Old Nov 9, 2005 | 09:14 PM
stooze's Avatar
stooze
Default very easy...
if you have someone else do the install.
Old Nov 9, 2005 | 09:17 PM
stooze's Avatar
stooze
Default sorry...
really though I'm having a speed shop do it along with other mods...LSX intake, headers with sensor probe and instrurments pod on the "A" pillar. I'm going to monitor EGT and O2/gas mixture. Just for fun
Old Nov 10, 2005 | 08:58 PM
Jettech's Avatar
Jettech
I installed Dynotech's on mine. Absolutely no problem. Take your time as mentioned above and follow the instructions, and you will be fine. I promise you will love them!!
To help with headers
Old Nov 12, 2005 | 12:29 PM
REDLYNER's Avatar
REDLYNER
HOW DO YOU GET THE LAST BOLT OFF EACH MANIFOLD????????
Its the bolt that is tucked way back in there. I spent two hours last night trying to get those last ones off. Before I go back to it, any advice?
What tool makes this easier?
Thanks!
Old Nov 14, 2005 | 07:23 PM
bcseitz's Avatar
bcseitz
Greg
And don't forget to by the two little air tube to exhaust manifold gaskets too! Mine were in rough shape when I did my Stainless Works Header install this past weekend.
And by the way, I'm gonna pay the pro's to do the install next time!!!
Old Nov 16, 2005 | 12:07 AM
Steve Utanoff's Avatar
Steve Utanoff
Cruising
Default HEader install C5
This link outlines the LGM header install
http://www.ls1howto.com/index.php?article=29
