Redline Diff Fluid ?????????
Old Nov 8, 2005 | 12:44 PM
kawasaki eric's Avatar
kawasaki eric
Default Redline Diff Fluid ?????????
I have a 2003 a4 coupe 4000 miles rear diff is leaking from cover on drivers side. Would just changing to redline possibly stop the leak as i've read. Car is still under warranty for another year and the leak is very minor 1-2 drops occassionally. THANKS FOR ANY INPUT
Old Nov 8, 2005 | 04:39 PM
kawasaki eric
ttt
Old Nov 8, 2005 | 05:16 PM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
No probably not. If its under warranty, just bring it to your dealer, they'll fix it.
Old Nov 8, 2005 | 05:19 PM
FKING1's Avatar
FKING1
Fred
Old Nov 8, 2005 | 05:23 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
We are a dealer for Redline, and it will not fix a bad seal design.
Randy
Old Nov 8, 2005 | 08:24 PM
Lovin It!!! - C5's Avatar
Lovin It!!! - C5
I don't think he was asking if it would fix GMs poor seal design. I think he was asking if the Redline would cause the seal to swell and stop the leak much like the "cure alls" that they sell on aisle of evil at Pep Boys.
Even if you add something to stop the leak, its very temporary. Much smarter in the long run to fix the seal. Also much cheaper than a new diff if you don't catch the leaking before the oil level gets too low.
Good Luck
Old Nov 9, 2005 | 10:04 AM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
I know he wasn't asking about the design. But about 9 out of 10 seals leak before 50,000 miles.
Randy
Old Nov 9, 2005 | 10:15 AM
BradSW's Avatar
BradSW
From: From San Diego to Bentonville, AR.....WTF was I thinking?!? Oh yeah, that free state thingy!
St. Jude Donor '15-'16
I've had Redline in my diff. since about a month after buying it two years ago, and I got the leak two months ago. Had dealer fix it and no problems since, but now I have the GM fluids back. Will change to Redline again eventually.
Brad
Old Nov 9, 2005 | 11:26 AM
MadMaxZ06's Avatar
MadMaxZ06
Default Go see Steve Spencer!
Eric,
This might sound crazy, but if I were you I would take my vette to go see Steve Spencer at Bryner Chevrolet in Jenkintown, PA (It's 1.5 hours away for you). I live in Virginia and have gone to see Steve twice (for me, it's 2.5 to 3 hours each way, but it's worth it), this last time to have him fix my leaking rear diff. I couldn't be happier!
Also, listen to what other people have to say about him:
http://forums.corvetteforum.com/show..._id=103&arch=1
http://forums.corvetteforum.com/show...um_id=1&arch=1
Get it done right the FIRST time! Bryner # (215) 886-3140
- Max
Old Nov 9, 2005 | 04:01 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I would get this fixed, especially since your car is under warranty. While you may think the leak is only 1-2 drops, you probably don't know how much is leaking while driving and not dripping on the garage floor. Unless you check your diff fluid level regularly, the risk is that you run the fluid low... which is not good.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 9, 2005 | 04:21 PM
boosted_z06's Avatar
boosted_z06
No it will not fix it and could instead cause it to leak more for when GM designs parts they do so in using a certain oil that works with those parts such as gaskets and O-rings
If the car is still under warranty I suggest when you take car in for warranty repair that the GM fluid is what they find in transaxle
Being the car only has 4,000 miles in 2 - 3 years the leak would be worse if driven daily so you should have the warranty work done now.
Old Nov 9, 2005 | 08:03 PM
kawasaki eric
Thanks for all the information!!!!!!!!!!
I will get it taken care of before the warranty runs out.
Old Nov 9, 2005 | 08:04 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Get the dealer to fix it!!!! THEN CHANGE IT TO RED LINE!!
Old Nov 9, 2005 | 08:42 PM
SmashF15C's Avatar
SmashF15C
FYI mine dripped a bit when I got it at 20K miles - tightened the cover bolts around the rear of the diff - all is well.
May try if you don't feel like giving your car to the dealer (yuck)
HTH
Smash
To Redline Diff Fluid ?????????
