Turn Signal
Old Nov 8, 2005 | 11:52 PM
billman2's Avatar
billman2
3rd Gear
Default Turn Signal
Hey. My 99's right rear turn signal doesn't work / blink. The bulbs are new, no noticeable shorts in harness or sockets. replaced the hazzard / flasher switch / relay. (its went pretty well, following instructions as posted on this Forum ) replaced micro relay, fuse good.....help.
Old Nov 9, 2005 | 10:43 PM
down under's Avatar
down under
5th Gear
Default turn signal
have had the same problem i am dealing with it at the moment, it is turn signal switch, or check harness at the base of the column for bad contacts.
Old Nov 10, 2005 | 02:06 AM
jophis37's Avatar
jophis37
take it for what it's worth. When I changed my front blinker, It wouldn't blink at first but after pulling the bulb back out, turning it 180 degrees and reseating it it worked. I'm sure your past that. But just though I'd throw that one in there.....
Sorry to hear your having problems
Old Nov 10, 2005 | 11:43 AM
jag71usa's Avatar
jag71usa
When you activate your turn signal and it does not work, activate your emergency flashers, when they come on, deactivate them. Your turn signal should work. Again, this is a quick fix. My have been doing infrequently and I get them to work again by doing this.
Old Nov 10, 2005 | 02:45 PM
LarrySutherland's Avatar
LarrySutherland
Cruising
How did you get in to change out your front blinker? I bought mine used w/o a service manual. Thnx!
To Turn Signal
