How do I get a spare key? VATS...
Old Nov 9, 2005 | 06:21 PM
CarolVettes's Avatar
CarolVettes
From: Do you know what they call a Quarter Pounder with cheese in Paris?
Cruise-In VII Veteran
St. Jude Donor '06
Default How do I get a spare key? VATS...
I need a spare ignition key. My key has the resistor on it. Do I have to go to a dealer? How much is the key, and the cutting?
Thanks!
Old Nov 9, 2005 | 06:42 PM
rws.1's Avatar
rws.1
The dealer wil charge you about $45 for the key and to cut it.
You can buy one on ebay a lot cheaper and then take it to any locksmith to cut it.
Some lock smiths may have them in stock and may have an "interrogator" to tell them which of the 16 possible resistor pellets they need.
You can do the same thing your self if you have access to a digital volt meter and read the resistance of the pellet.
I know there are posts on here that tell whicdh risitor you need based on the resistance.....
I'll take a quick look and see it I can find the one I recall....
Old Nov 9, 2005 | 06:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You will need to go to the dealer. If my wife was awake, I could tell you how much each thing was. It isnt cheep!! I think each key is 15 bucks a cutting was 10 bucks but I would be guessing.
Take your car and make sure that the key works after they cut it. Dont just start the car. Make sure that you drive it around the parking lot to make sure that the resistor for the security system is the correct value. If you dont move the car, it may start but if the resistor pellet is incorrect, the BCM will shut down the engine after the car moves a few inches.
If my wife gets up, I will see if she remembers how much we paid for our keys.
BC
Old Nov 9, 2005 | 06:47 PM
rws.1's Avatar
rws.1
here is the link to the thread I recalled
http://forums.corvetteforum.com/show...e&forum_id=103
Old Nov 9, 2005 | 07:04 PM
Lovin It!!! - C5's Avatar
Lovin It!!! - C5
Just bought one at the Chevy dealer for $20 and they cut it without asking for any more $. Guess it varies widely by dealer.
I'd call each of your local dealers and ask them.
Old Nov 9, 2005 | 07:54 PM
minytrker's Avatar
minytrker
I gave the dealer my VIN and they told me which key I had, but like someone said already you can check it with a ohm meter to find out which one you have. I then went on ebay and bought a key for $25 shipped and had it cut for free at Ace. The dealer told me $65 or $80 for a key I dont remember.
Old Nov 10, 2005 | 12:41 PM
MattB's Avatar
MattB
Any good locksmith will have the correct key, the resistor keys are pretty common, nothing real special. But, definately shop around as the posts above indicate there is a lot of variation in what a shop will charge.
Old Nov 10, 2005 | 12:49 PM
rhoge's Avatar
rhoge
I agree. A local locksmith shop here had the key I needed and they cut it. All for $25. Check around.
Old Nov 10, 2005 | 03:24 PM
2kbluestreak's Avatar
2kbluestreak
Resistors are common, but that little pellet that fits into the rectangular hole in the key looks very special. The keys may already come with the specially coded resistors in them, or the locksmith may be able to press them in: I just don't know about that part of the deal.
I do figure that locksmiths that say they have to "interrogate the chip" instead of "put an ohm meter across the resistor" are likely to charge more.
Old Nov 11, 2005 | 03:04 AM
lt1george's Avatar
lt1george
Give the dealer(any GM dealer) your vin # and he'll tell you the code. Buy the correct key on ebay and go back and have him cut it, or any locksmith. If you want a nice looking GM Corvette key... get the 2003 Corvette key. It's good for any 97-04 Corvette. Looks alot better the the plain black Chevrolet emblem .Save the Wave.>George ps Carol....to answer your other question, it's called a " le royale cheeseburger"
Old Nov 11, 2005 | 09:03 AM
c4cruiser's Avatar
c4cruiser
You may be required to show some ID and the car's registration slip at the dealer. A lot of dealers require that so they don't make a key for a stolen car. Not a big deal, but if the dealer wants that info and you didn't bring it, you would be SOL.
To How do I get a spare key? VATS...
