Help! Newbie
Old Nov 10, 2005 | 09:01 PM
NDRAG's Avatar
NDRAG
Default Help! Newbie
I found both drain plugs for the tranny,( manual) and rear end, differential). Now where do I fill them!! Got it on jack stands, ( that was fun!), so theres not much room for my fat a#%! 6'7" 250!. I've got 4 quarts red line synthetic ATF, and 2 quarts red line 75-90 synthetic rear end oil. Now if I just knew where to put them! Thanks for any help John
Old Nov 10, 2005 | 10:27 PM
NDRAG's Avatar
NDRAG
Anybody know where the fill plugs are! Thanks in advance
Old Nov 10, 2005 | 10:37 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
the tranny fill plug is on the passenger side....rear end is on the back .....the tranny is easy as you can use a wrench..rear end you need special tool...its pretty obvious when you get under there.....I hope you have a pump to fill them with otherwise you are gonna make a fkin mess
Old Nov 10, 2005 | 10:51 PM
cortex's Avatar
cortex
Well, they are higher up than the drain plugs. Sorry.
Search yahoo for 'c5 transmission fluid change' and click the second link for pics.
Can't find pics of the diff but I think the fill is on the back. It is slightly painful to do single handedly, I remember that. You are going to need a fluid pump, that's for sure.
To Help! Newbie
