Just bought a C5 vert originally sold in Canada, any way I can get the twilight sentinel feature to turn off. I heard on the Canadian cars there's no way to turn it off. How about it?
I do not see what year is you car, but in case you have an early C5, removed the BCMI 3 minifuse # 22 from the IPEC (instrument panel electrical center) located at the right of the BCM. Parking lights are still controlled by sensor, but I need to turn the switch to have the head light to come up. This is what I did on my 97.
good luck.
_______________________________
Stock 1984 & 1997 A4 Z51 3.15. BestTime 13.36 on Michelin Pilot. 18 inche wheels all around for the look. Hawk HP+ for braking. Corsa for the sound.
If you have a '99 or newer, get to the fuse panel behind the footrest on the passenger side, pull the relay fuse #44, you may need some long nose pliers.
Everything will function normally but the headlights will not pop up automatically anymore.
That did it for me on my '03.
No speed brakes when racing at the drags at night now ....
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
had mine set up that way for almost 2 years . then i thought I have the option why not have it work the way it should .so i had my vette tech change it . I have never used it since . kinda liked the way it worked before the road light only came on
