Clutch Return Spring Broke???
Old Nov 11, 2005 | 04:06 PM
turbo altezza's Avatar
turbo altezza
Default Clutch Return Spring Broke???
so somethign snapped underneath my clutch and it looks to be the clutch return spring, the clutch still works but i dont know how this will effect it and how long i can drive the car in its condition...... what should i do. the nearest chevy dealer is like a hour + away.
Old Nov 11, 2005 | 04:14 PM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
If the spring fell in the floorboard,it is a helper spring. It works better without it. A lot of us Vette owners removed them.
Old Nov 11, 2005 | 04:20 PM
jmiller's Avatar
jmiller
I removed mine about month ago. I like it much better.
Old Nov 11, 2005 | 04:46 PM
jhong321's Avatar
jhong321
i pulled mine out as soon as i got the car. i also have a friend with the sticking clutch pedal problem and i pulled his spring out and he has not had the problem since.
Old Nov 11, 2005 | 07:33 PM
John S.'s Avatar
John S.
what does this spring look like? The only one i saw was a double coil spring about half way up the pedal.. looks like a return spring more than a helper spring. Does anyone have pics of it? the search feature is disabled right now
Old Nov 11, 2005 | 08:03 PM
jmzvet's Avatar
jmzvet
This spring assists the clutch pedal on the DOWN stroke.
Old Nov 23, 2005 | 12:29 AM
jmfol's Avatar
jmfol
Default How does the clutch pedal feel after the spring has been remobved /
I am considering removing the clutch pedal spring as well. To you guys who have done the mod, how do the pedal rest when not in use, i.e does it have some play or does it stay up firmly like before ?
Thanks,
JM
Old Nov 23, 2005 | 06:43 AM
John S.'s Avatar
John S.
Thanks,
JM
mine feels like it has about a 1/2" of travel without it, ofcoarse my hydraulics are all messed up too so that could be the culprit. I like the mod myself.
To Clutch Return Spring Broke???
