Replacing the headlight relay
Old Nov 11, 2005 | 10:22 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default Replacing the headlight relay
is it very difficult?
Old Nov 12, 2005 | 05:44 PM
markcz's Avatar
markcz
It shouldn't be! Just a standard pull out/push in as far as I know.
If you haven't already pulled it out to test it, what makes you think it's bad?
Old Nov 12, 2005 | 09:09 PM
Markm10431's Avatar
Markm10431
Parrothead
buzzing noise from the front when the lights go down. lasts about 5-10 seconds then stops. very simular to the right headlight problem on my saturn
Old Nov 13, 2005 | 01:53 PM
markcz's Avatar
markcz
I doubt the problem is a relay, there are two common problems with the headlights.
One is due to the stopper under the light housing needing an adjustment, there's a procedure on the forum somewhere for how to properly adjust it that you can probably find once search is working again.
The other, and most common problem, is a damaged gear inside the actuator. If it's a nasty grinding noise that you hear, then that's probably your problem. You can buy a new motor/gear assembly from GM for some major $$$, fix it for free using these instructions, or buy some metal gears and make it last. There are several places that sell the metal gears, do a search on the net for 'corvette headlight gears' and see what comes up.
To Replacing the headlight relay
