well damn, i have a huge chunk of diff case under my car. its not looking good. the tranny is freshly built w/less than 500 miles on it . RPM M12 . shifted like butter . i would hate it if my rear took it out of comission. it was a A&A 4.11 rear that shattered.this sucks
-jonathan
-jonathan
Sorry to hear of your breakage and hope your transmission is OK....... I'll bet it was running like a raped-ape before it went.
Sorry, couldn't resist. Good luck with the repairs.
-jonathan
if it was a RPM and you opted for the upgraded output shaft and broke it .. i'd like to see pictures.
what'd you do to crack it? just really bad wheel hop?
i didnt get the upgraded shaft.
i dont think there was enought water on the tires when i started the burnout. (mt et street radials). and it wheel hopped really violent one time so i let out, but it was to late.
-jonathan
there arent any noises or funny sounds comming from the tranny. is that a good sign? when i put it it gear and let the clutch out its silent. ,..........just doesnt go anywhere lol
-jonathan
-jonathan
well you probably wont really know anything until you pull the diff from the tranny ... you may have been lucky and only cracked the diff .. "lucky" .. i guess that's a figurative term ..
you could have damaged the shaft, a few teeth on it .. or it could be fine .. like i said you probably wont know until you've got it apart.
This story sounds all to familiar. The same thing happened to me about 1.5 or 2 months ago. My car is down at ecs getting fixed right now. Well when you get it fixed don't forget your DTE Brace.
