Noise when pulling away from stop. Help
Old Nov 12, 2005 | 08:52 PM
wolfman04's Avatar
wolfman04
Default Noise when pulling away from stop. Help
I have a 04 A4 when pulling away from a stop I here a clunk it sounds like it's coming from
the right rear, it doesn't do it all the time I would say about 80% of the time.Anyone know
what it might be?
Old Nov 12, 2005 | 09:25 PM
konish's Avatar
konish
Grease the rear, wheel-side drive splines of the half-shaft. Mine did the same thing and a little grease did the trick. Found the tip here on the forum.
R/
D
Old Nov 13, 2005 | 09:14 AM
wolfman04's Avatar
wolfman04
R/
D
Thanks konish, is there a grease fitting somewhere if not how do you get to it? I got a free
oil change certificate from GM will they grease it when they service the car?
Old Nov 13, 2005 | 09:23 AM
69's Avatar
69
Cruise-In VI Veteran
There are no grease fittings....If there is a "clunk" noise, it can be many things>
CV joint
Ball joints
Wheel bearing
Stabilizer bar
Get you car checked out by a certified ASE Tech..soon!
To Noise when pulling away from stop. Help
