My right side window doesn't open and close any more. I hear a click when I engage the electric switch but I don't hear the motor run and the window doesn't open.
How do I take the door panel of to investigate this problem?
Does anyone know what would cause this? My 2k had the same thing happen today. I push the window button and hear a clicking sound but no window movement.
How do I get to the DIC Codes? Shouldn't I get one of the following codes telling me what is wrong?
A1-RDCM - Right Door Control Module
B2203 Right Window Up Switch Fault
B2205 Right Window Down Switch Fault
B2237 Right Door Lock Switch Fault
B2239 Right Door Un-Lock Switch Fault
B2253 Key Cylinder Switch Fault
B2263 Horizontal Position Sensor Fit
B2265 Horizontal Position Sensor Fault
B2273 Right Mirror Motor Fault
B2275 Window Motor Fault
B2277 Door Lock Motor/Mirror Heater Fit
B2283 Battery #1 Fault
B2285 Battery #2 Fault
B2287 +5V Reference Fault
U1064 Loss of Communications with BCM
U1096 Loss of Communications with IPC
U1255 Serial Data Line Malfunction
