Code U1016 and Hard to Start
It eventually starts after one or two attempts or if I give it throttle.
When it happened today (first time in 10 days) it threw a code U1016.
This NEVER happens on cold starts!!
This has been happening since new feul pump, FLP tranny and torque converter installation. Never happened before.
Dealer says new feul pump is fine.
Tuner adjusted tune and has been better.....may just need another adjustment.
But thought I would check here to see if any other issues could cause this or if dealer is full of ****.......what do ya think???????
DH
DTCs U1001-U1254 are lost communication error messages. The C5 modules are connected via a class 2 serial data circuit. Each module on the class 2 serial data circuit which is powered and performing functions that require a detection of a communications malfunction is required to send a Node Alive message every 2 seconds. When no message is detected from a module in 5 seconds a DTC will be set. The last 3 numbers in the DTC is the ID number of the module that is not communicating. (e.g., U1016C - In this case 016 is the module ID for the PCM.)
The U1016 DTC may or may not be connected to your starting problem, but one really needs to know which module(s) are reporting that code to help make that determination.
The code was U1016 H from the RFA module (last one as you page thru modules).
DH
DH
http://www.gearchatter.com/viewtopic10635.php
Good Luck
Leo3
DH
BC
BC
Yes I have mods (see below)
Yes, as stated above I have had FLP tranny, Vigilante TC and dealer replaced feul pump before this started to be a problem
The car idles fine (750rpm) all the time and NEVER does this on cold starts.
I am trying to eliminate any possiblities other than needing a tune adjustment.....like bad feul pump or air leak that would act up only on a hot start and then only intermittantly.
PS: Thanks everybody else for your input
DH
Recommend checking the fuel pressure at the fuel rail when you are having the failure to start issue. When you turn the key to "ON" you should hear a low pitched hum that runs for about 8- 10 sec. That is your fuel pump running to charge the fuel lines.The pressure should remain constant and should not leak off. You should see right around 55 ish psi. Im sure some one will jump in and give you the exact pressure.
If your loosing pressure or your pump has a loose electrical connector and is cutting out, you can see hard starts and engine stumbling. It womt set codes either. The U code that your seeing is a fluke and has nothing to do with your problem.
BC
BC
Thanks for your thoughts. And I will get my tuner to check for pressure. Should I here the hum from the feul pump behind me or some thing in the engine bay. Should I turn my key to on for a few seconds always before starting......I never do....I just quickly turn it to on. BTW the reason they replaced the pump was because I was complaining of it occasionally making a high pitched humming noise.....it doesn't anymore.
Thanks for your help......
DH
