99 Power Window
Old Nov 14, 2005 | 05:20 PM
Lickitty's Avatar
Lickitty
Default 99 Power Window
Got the Passenger side Window working but notice I have a Broken Plastic Pulley
This looks like a $3 piece of plastic
Where can they be bought new or used ??
Old Nov 14, 2005 | 06:49 PM
z06matt's Avatar
z06matt
I would try a Chevrolet dealership parts department.
Old Nov 14, 2005 | 07:17 PM
Lickitty's Avatar
Lickitty
They want over $200 for a Whole Window Regulator
I need a $3.00 Plastic Wheel from that whole Assembly
Old Nov 15, 2005 | 02:18 AM
GrayC5's Avatar
GrayC5
Try Gene's Kar Shop, a supporting Forum vender.
Old Nov 15, 2005 | 12:17 PM
Lickitty's Avatar
Lickitty
Thanx Gray
I'll try them
Any other ideas in case this does not work out
Old Nov 15, 2005 | 08:36 PM
Lickitty's Avatar
Lickitty
Default Power Window Regulator
Ttt
Old Nov 15, 2005 | 08:41 PM
78Vette-SA's Avatar
78Vette-SA
Curious how you got it working?
Old Nov 15, 2005 | 11:39 PM
Lickitty's Avatar
Lickitty
Took off Door Panel to get to Motor.
Motor was warm so it was trying to work .
I could hear the window switch clicking so it was working
* * I also watched the Voltage guage slowly dropping as I tried to make window go down ( have to watch very very closely as only dropped 1 volt in 5 seconds **
Took the motor out ( 3 nuts )
Took cover off 6 Torx Screws then carefully noted ( took Digital picture of where cables went ) and pulled the pulley from gear in motor
* Have someone hold glass when you do this *
Didn't see anything wrong ????? so put together again then noticed a cable pulley coming off ? and discovered I had a broken pulley so I assume it was bound and could not work , thus the warm motor
Now I need a $ 3 pulley but everyone wants to sell me a whole Window Regulator $125 used and $250 New
To 99 Power Window
