Drill Mod ? Need Help
Old Nov 14, 2005 | 08:48 PM
C5-JIM's Avatar
C5-JIM
Default MASTER CYLINDER Drill Mod ? Need Help
I am replacing my slave and master and installing a spec 3. Do I need to do the drill mod ? On the f-body they drill the end going into the master. The restriction on the Vette is where it couples to the slave. Is that were you do the drill mod on the master end ?
Thanks, Jim
Old Nov 15, 2005 | 10:48 AM
RoadRebel's Avatar
RoadRebel
The big rerstriction on the C5 is there the hose goes into the slave asm.
Just remove the roll pin and pull the line out. Once its out look in the end you just removed and all will be revealed
Phil
Old Nov 15, 2005 | 01:35 PM
6Speeder's Avatar
6Speeder
There are three restrictors in the C5 clutch hydraulics, one at the output of the master, one halfway down the line in the hard 90, and one in the input to the slave.
To Drill Mod ? Need Help
