Zip Tie intake mod
Old Nov 16, 2005 | 04:53 PM
C10 JDR's Avatar
C10 JDR
Default Zip Tie intake mod
What is it?
Old Nov 16, 2005 | 05:05 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It is when you remove the air cleaner cover and hold the filter down in place using zip ties. IMHO not worth the risk of the filter coming off. Just get a 03' Z06 cover or drill holes in your cover.
Old Nov 16, 2005 | 05:13 PM
C10 JDR's Avatar
C10 JDR
Thanks.
Old Nov 16, 2005 | 06:01 PM
lost's Avatar
lost
This worked very well, until I switched to Halltech, havent been to track to test Halltech but I honestly feel this works as well if not better.
Old Nov 16, 2005 | 06:14 PM
C10 JDR's Avatar
C10 JDR
Well I have the thing off now, and I honestly cant see how they could have designed a more restrictive shroud.
Massive lump of plastic in a basically blind space. Even chopping a dirty great hole in it (as above) is not that great, as it is up against the front bumper.
Anyhow I will do that, and cut some holes in the foglamp housing - my poor baby is suffocating in there..
Thanks for the pic Lost - useful
Old Nov 16, 2005 | 08:12 PM
rc51racer's Avatar
rc51racer
I cut holes in the air box lid at first but when I put it back on it didn't seem to let anymore air in just by looking at the position it was facing. I then read about the zip tie mod and just happened to have some extras laying around after my heating and air ducting work in my basement. I discarded the cover and went with this design. I also removed my fog light panels and cove vent covers. Now the zip tie mod is not the prettiest you ever seen but I am the only one that will ever know. Just make sure you tighten those zips very tight. Overall it seems to pull alot better through the RPM range after doing this. Best of all it is free!
Old Nov 17, 2005 | 01:00 AM
LKGRenegade22's Avatar
LKGRenegade22
I did the zip tie on my 02 Z06 with a K&N and used commercial sized (HUGE) zip ties and the install looked clean. Honestly I couldn't really tell a difference in how the car felt. I just recently upgraded to a Halltech TRIC system and that is a different story. That is a true seat of the pants difference!
Old Nov 17, 2005 | 07:00 AM
C10 JDR's Avatar
C10 JDR
I assume I don't need any programming - will the MAF take care of it?
Old Nov 17, 2005 | 07:05 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
You are correct, well within the stock adjustment params, no PCM mods required.
Old Nov 17, 2005 | 08:29 PM
SGT. PYLE's Avatar
SGT. PYLE
This is what I did....
Old Nov 17, 2005 | 11:45 PM
Roc87's Avatar
Roc87
As you can see in SGT. PYLE's pics, he has hood weather stripping at the front, if you don't have it, it's possible that water will drip directly onto the filter.
Old Nov 18, 2005 | 11:11 AM
C10 JDR's Avatar
C10 JDR
Good point. I will address that very concern..
Old Nov 18, 2005 | 04:11 PM
screw991le's Avatar
screw991le
Just get a roll from autozone, it is 12 bucks and will do 2 cars. Do be fooled by the "performace hood seals" people try to sell for 30 bucks
To Zip Tie intake mod
