Track pad suggestions
Old Nov 16, 2005 | 08:04 PM
ecudooberhead's Avatar
ecudooberhead
Default Track pad suggestions
Im doing a drivers ed at VIR next month, and I want to get some very aggressive track pads- any suggestions? I am currently using HP+...
Old Nov 16, 2005 | 08:18 PM
GUSTO14's Avatar
GUSTO14
The Hawk HP+'s are actually a pretty aggressive pad, you might want to give them a try your first time out. Hawk also makes a more aggressive pad as well the HPS.
I personally like the EBC's... Green Stuffs for the street (comparable to the HP+) and the Red Stuff's which are much more aggressive.
VB&P has a pretty good selection of pads and you also get a 10% discount by being a Forum member.
Good luck... GUSTO
Old Nov 16, 2005 | 08:21 PM
ecudooberhead
The HP+ are definately decent pads- I use them on the street, but im not sure if they are up to snuff for a road course event.
Which of those you listed are the most aggressive? I am only using them on the track, so any drawbacks to the pad are not important (pad life, brake dust, loudness, etc)
Old Nov 16, 2005 | 08:37 PM
GUSTO14's Avatar
GUSTO14
Of the ones I mentioned I believe the EBC Red Stuffs would be the most agressive, but this is a question that might better be answered on the Autocrossing and Roadracing Forum... those guys take their brake pads very serious...
GUSTO
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Wilwood H pads are great! PFC 01 are good also.
Old Nov 16, 2005 | 08:53 PM
ecudooberhead
Good suggestion- I will post the question over there- thanks for the help
Old Nov 16, 2005 | 09:10 PM
UstaB-GS549's Avatar
UstaB-GS549
Try the Carbotech XP9 front and Panther Plus rears. Call and talk to Matt or Larry. They are reasonably priced, stop well, rotor friendly, clean-up easy and you can drive them on the street if you don't mind dust levels and squeaking every once in a while. The dusting is a little bit more that the stock Z06 pads.
Old Nov 16, 2005 | 10:14 PM
lspalding's Avatar
lspalding
What I was going to say. Have used this combo and it works very well with no fade. And did not have to change out for the street.
Old Nov 16, 2005 | 11:26 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I've tried Hawk HT14, PFC-01 and the Carbotech line. Haven't tried the Wilwoods. I settled on the Carbotech and have been racing on them for the past two seasons and am very happy with the result.
This season I used the XP11 front, XP10 rear on DOT R compound track tires. These pads might have too much bite on street tires for your taste, though I did run them in a damp session this year on Kumho Ecsta MX's mounted on my stock rims and I thought they were fine.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 17, 2005 | 05:36 PM
ecudooberhead
I think I am going to look into the Carbotech XP10f and XP9 rear- any suggestions where to pick these up? I looked at a few tuners and didn't see any listing for brake upgrades
Old Nov 17, 2005 | 09:14 PM
C66 Racing's Avatar
C66 Racing
Forum vendor pfyc.com is a Carbotech retailer.
Old Nov 17, 2005 | 09:47 PM
ecudooberhead
Excellent, I will be calling them tommorow
Old Nov 19, 2005 | 12:46 AM
corvettefrance's Avatar
corvettefrance
HP+ are decent pads for track days.
As soon as you will use HT10 or HT 14 you will see a big difference in braking distance especially if you are using slicks.
On short braking HP+ is ok you really see a big difference at braking over 100 to 40.
Carrefull the HT 10 or HT14 are racing pads they work at very high temperature be sure to have a high temp fluid too or you may have a bad surprise
To Track pad suggestions
