fob issue
Old Nov 17, 2005 | 08:01 PM
maddman's Avatar
maddman
Default fob issue
Fob will not resynch.followed instructions on DIC .nothing. 3 volts at contacts .how can I tell if fob is working?Am i missing something?
Old Nov 17, 2005 | 08:24 PM
servohead's Avatar
servohead
Well, there IS a special tool that verifies that the remote is sending out a signal - however you probably don't have one. In my experience, if a resync doesn't work then you most likely need a remote. That's what worked for me. I've heard of rare cases where the receiver in the car is at fault, but again that's rare.
Old Nov 17, 2005 | 10:33 PM
maddman's Avatar
maddman
where coul i get the fob tested to see if it is working
Old Nov 17, 2005 | 10:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The Remote Function Actuator (RFA) receives the signals from BOTH the FOB and Trie Pressure Sensors (TPS). If your TPS are functioning properly, so should the FOB. Do you have a spare FOB? The car should have come with two. If you dont have a spare, the best place to find one for a good price is E-bay!
Early FOBs (97-2000) are a lot more money than the later FOBs (2001-2004) What ever year C5 that you have, you MUST get the type of FOB that came with it (97-2000) or 2001-2004). You can NOT use the newer type FOB if you have the older C5 FOB!
How are you programming the FOB? There are two different procedures.
There is a RE-Sync procedure and there is a RE-Learn procedure. Do the re-learn as per the procedure in the owners manual or in the C5 Tech Tips section and let us know what happens.
Bill C
Old Nov 17, 2005 | 11:07 PM
maddman's Avatar
maddman
I dont have a manual and the car came with 2 fobs please walk me thru both proceedures
Old Nov 17, 2005 | 11:21 PM
W Muller's Avatar
W Muller
Default fob
You can go to the GM website and register with them. You will have access to an online owners manual for your car.
To fob issue
