I was on Corvette Action Center and found a bulletin about 2001's and (After Market Stainless steel brakes lines on 2001's that cause codes or problems with Active Handling or Brakes, sending mixed signel because of static caused from the Stainless lines)
Are there any other bulletins or anything else regarding this topic and anything about wheels sensors. I've read alot of problems about codes set off because of the harness on the left wheel. Is there any bulletins about this from Chev.
Any help in the department would be very helpful and greatly appreciated.
