Winter Storage Question: Fill gas tank or leave empty??
Old Nov 18, 2005 | 12:26 PM
ADE 1000's Avatar
ADE 1000
Default Winter Storage Question: Fill gas tank or leave empty??
In the past, I have always filled my gas tank prior to storage. I did it because it seemed to be common practice to avoid condensation, but after thinking about it some more I am not sure it makes sense. Is there really a need to do this since our cars do not have metal gas tanks?
My Z is currently all prepped for storage (washed, Zainoed, new oil,etc..) but the tank is bone dry. I never got a chance to go fill it up before we got hit with some bad weather. The streets were prematurely salted a few days ago due to some snow flurries and I'd rather not take the car out again.
Old Nov 18, 2005 | 12:36 PM
vettenuts's Avatar
vettenuts
I do, maybe a carry over from my boating days. But also concern about the stupid gas gauge sending unit. Gas may be $10 a gallon in the spring to
Old Nov 18, 2005 | 12:47 PM
dbvettez06's Avatar
dbvettez06
Fill as full as you can...
Old Nov 18, 2005 | 12:59 PM
ADE 1000's Avatar
ADE 1000
Why?
Old Nov 18, 2005 | 01:00 PM
SpeedyZ's Avatar
SpeedyZ
I would filler up and add some StaBil Fuel Stabilizer. I don't think the plastic tanks will make much difference since you still have the pump, screens, and sender in there to worry about. If it was in fact "bone" dry I would say leave it empty, but unless you have had the tanks off you probably still at least a gallon of fuel in there. And a small amount of fuel is going to dry up and get messy quicker than a full tank. I don't think the condensation factor is as big in new car as it was in the old days. These cars in "theory" have a sealed fuel system and they "should" stay under pressure so they "shouldn't" draw moisture. But that is all in theory. I'm sure they are better than in the old days. I would worry more about that small about of gas drying up and causing a mess more than I would worry about condensation. If nothing else just buy you as large 5 gallon can and make 4 trips to the station. That would be much easier than cleaning the car again! If you go that route I would put a little StaBil in the can each time before you put the gas in the can. Be sure to run the car a little afterwards also to be sure it get worked up through the system.
Old Nov 18, 2005 | 01:29 PM
EHS's Avatar
EHS
Originally Posted by ADE 1000
Why?
Old Nov 18, 2005 | 01:30 PM
rws.1's Avatar
rws.1
You want to put a gasoline stabilizer (Stabil) in it, fill it to the brim and run it for 5 minutes to get the Stabil into the injectors.
The more full , the less opportunity for condensation to form and get both water into the gas and corrode metallic parts of the system.
If you are worried about fouling the sending unit, just till it with a top tier gasoline www.toptiergas.com
or also add a bottle of Techron or Berryman Chemtool B-12
Old Nov 18, 2005 | 01:49 PM
dbvettez06's Avatar
dbvettez06
Why?
H2O bad for engines!!
Old Nov 18, 2005 | 02:04 PM
jimcork1's Avatar
jimcork1
Originally Posted by SpeedyZ
I would filler up and add some StaBil Fuel Stabilizer. .
If you are only storing in the winter,, fill it up, add the Stabil fuel then run for a few minutes to pull the fuel stabil through the fuel system.
Old Nov 18, 2005 | 04:52 PM
ADE 1000's Avatar
ADE 1000
Thanks for the responses. It looks like I'll be making a trip to my local Amoco station this weekend.
Old Nov 18, 2005 | 06:38 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
FYI, get a battery tender
Old Nov 18, 2005 | 06:41 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
This is a MUST
Old Nov 18, 2005 | 08:37 PM
IM QUIKR's Avatar
IM QUIKR
The gas also keeps the seals flexible preventing leaks months down the line. Fill'r up
Old Nov 18, 2005 | 08:58 PM
screw991le's Avatar
screw991le
The weatherproof Batter tender JR from Beltran works awesome for me. It gets covered in snow and works fine, I am on my second winter with the tender and I love it.
Old Nov 18, 2005 | 09:09 PM
hhntr111's Avatar
hhntr111
I agree...fill to the top. I add Tachron and Stabil, run it for ten minutes to make sure it gets through the fuel system, and put the cover on.
Old Nov 18, 2005 | 09:16 PM
IM QUIKR's Avatar
IM QUIKR
I believe you may want to run it longer than 5 minutes. You fill the left tank with clean fuel but the right tank is actively pumped to the left so it may take a little more than 5 minutes to completely mix the Stabil in both tanks. Go zoom around for one last blast and really mix her up good.
Old Nov 18, 2005 | 09:31 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Winter storage=bad news for the vette.
To Winter Storage Question: Fill gas tank or leave empty??
Old Nov 23, 2005 | 09:38 PM
Bob Chapman's Avatar
Bob Chapman
Almost right - Winter storage = bad news for the vette owner/driver.
Old Nov 23, 2005 | 10:13 PM
IM QUIKR's Avatar
IM QUIKR
How so? This is the time for modding. May not be as fun as driving but it's the next best. My AC blower motor was dying and the driver's seat back was not holding it's position along with the rocking issue, so I pulled them out and dropped them off at the dealer for repair. Next will be a custom radiator support I'm going to fab-up and relocate some coolers in the front brake duct areas and install my hardbar and harness, plus a few extras I can secret into the house. It'll take a good 4 months to make the changes especially when it's this cold but it helps me bond with the car when I can't drive it.
Old Nov 23, 2005 | 10:22 PM
edensknight's Avatar
edensknight
